NO SOUND ON RECEIVING END WHEN I TURN ON MY VIDEO
WHEN I CALL, OR SOMEONE CALLS ME MY SOUND WORKS FINE UNTIL I TURN ON MY VIDEO, THEN THE SOUND STOPS.
ALL RECEIVING SOUND AND VIDEO WORK WELL.
    President:
  • 8,637 Answers
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Posted on Jan 30, 2009
I have a Pioneer VSX D412 S receiver with my Pioneer surround sound system The system SUDDENLY STOPPED RECEIVING SOUND SIGNAL FROM MY HD TV
  1. Turn the TV and receiver off and back on. This is called "power cycling" the devices.
  2. Check the menu settings to make certain the TV is still sending a sound signal out to the receiver.
  3. Disconnect the cable, blow both ends out, reconnect, and see if the cable was partially disconnected or has dust or lint interfering with the connections.
  4. Change the cable for another cable that you know to be working.
  5. Use a different source for the TV: DVD, Cable, different channel, etc.
  6. Connect the receiver to another TV.
Dec 16, 2015 | Pioneer Audio Players & Recorders
Front Speakers stopped working
turn on your video and start something playing, press the speakers button repeatedly until the sound comes back. this should bring back your front speakers, if it doesn't, double check your speaker connections and sound field program.
the speakers button should cycle through all available front speaker options.
Nov 16, 2007 | Yamaha HTR-6030 Receiver
I get the message "speaker
Have you looked in the manual?
I'd start disconnecting the speakers one at a time (from the receiver end) until it stops, then isolate the shorted wire or speaker.
May 22, 2011 | Yamaha Audio Players & Recorders
My tv lost picture and show only green screen although sound works
Hi, what you have is called hte "default " screen, the audio connection is apperebtly fine since you have sound, so the question is why video stopped. More than likely the video connection came loose somewhere, iI suggest retracing the " video connection " from end to end. If you're using an hdmi cable that has both audio and video cables combined-so it would be the cable or the player or jack on the tv's side that was defectice. if using standard " RCA " cables, those are the colors yellow, for video and red & white for audio. If someone or something become tangled in rca cables this may sometimes stress a connection and give a green screen ( with yellow cable still connected it will feel slightly loose ) I hope this helps ,good luck Prodzilla
Apr 10, 2011 | Sharp Televison & Video
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
The key pad on my phone does not work
I have the exact same problem. It started yesterday but I didn't even check the phone until someone said they called and I never received the call. Then this morning the phone was off so I power it on and it said the battery was almos dead. I charged it but couldn't look at a text msg that I had received. Now the only button that work is the power button. I bet it has something to do with Verizon network. I will contact them to see what they suggest unless someone fines a fix sooner. Thanks!
May 30, 2008 | Samsung SCH-a950 Cellular Phone
DVD video stops; audio continues
This definitely sounds like a circuit board-level issue. Have you tried moving to a different input set (i.e. if you're now on the TV inputs, try the DVD or AUX inputs for both video and sound)? Just to rule out the obvious, have you made sure that it's the receiver and not the DVD player? I know that you said you powered down the receiver, but if you had turned it off by pulling the plug on the surge suppressor and your DVD player is in the same suppressor, you might want to make sure it's the receiver and not the DVD player.
If you're sure that it's the receiver, then you might want to look into taking it to a Pioneer service center to have it repaired. If it's not worth the cost to you, it might be time to be looking into a new receiver.
Dec 10, 2007 | Pioneer VSX-D914 Receiver
Technics SA-DA10 Receiver-no sound
Most of these problems are rooted in a failed power amp module.
I'm working on an older technics unit but with the same troubles.
Aug 08, 2007 | Technics SA-DA10 Receiver
Computers & Internet Logo
David Payne
David Payne
