Question about Whirlpool LER5636P Electric Dryer
Wont start, power to all parts, is there a reset button?
My dryer wont start. I checked everything with a power tester and everything seems fine. Someone said there is a reset button near the motor and I could not locate it. Please help
  • 1,214 Answers
There is a wiring diagram on the access panel on the back, or in the control head.
Follow the path from incoming power through all switches and leading to the timer.
I suspect either the door switch or start switch has failed.
Posted on Jan 27, 2009
MY westignhouse LT819S has tripped the power and wont come back on. I can't find a reset button on the back.
You have not provided us with the complete model number, so I cannot look it up on "SearsPartsDirect", but I have never yet seen a clothes dryer with a reset button on the back, and I have been repairing dryers for 40 years.
Check the socket in the wall with an electrical tester and see if the house or apartment circuit breaker has been tripped.
If not, take the same tester and check all the components inside the dryer to find your problem.
God bless your efforts.
Feb 01, 2017 | Dryers
Got into accident car wont start where is kill switch
IT should be at the back part of the engine bay. See if the reset helps. Other than that check for loose connections or disconnected ground wires.
Feb 07, 2012 | 2005 Kia Spectra
Double check the power source, you may need to reset the breaker. It would be rare that the dryer would fault internally during transit because a gas ignitor you be the loss and you do not have one. Check the power supply and confirm you have at least 220 volt to wall and dryer. Get back to me if you need more help.
Nov 20, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Light inside dryer works fine, but lights for buttons wont turn on. So dryer wont start. It definitely is receiving power, but the buttons up top, on the front display will not even light up (regardless of...
i would double check the power a dryer runs on 220 volts if it is only getting 110 volts it will only run half of the dryer,, that means it could have power to the motor and light but not the control panel or vise versa 75% of the time when i work on a issue like this that is what it turns out to be,, take the cover off of the back of the unit where the plug goes in you will see three screws that the plug is held on with you will need a tester that reads 220 volts put one lead of the tester on the left screw and the othe on the right screw you should read 220 volts,, if not put one lead on the center screw and touch the other lead ont the other screws one at a time until you find which one doesnt read 110 volts,, if it reads the full 220 volts then you will need to check all the wires inside,, if all is ok you will need to replace the main control board
May 03, 2011 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Series 70 dryer wont start, just hums
Check for correct voltage at the terminal block on the back of the dryer, where the power cord attaches to the dryer.You should be getting 220/240 volts, check by way of a voltage tester.
If the voltage is correct, then could be the motor capacitor or the motor itself, or start button?
Good Luck !
Feb 07, 2010 | Kenmore 63942 Dryer
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
Have you checked the door switch, thermal fuse on the heater housing(this will keep it from starting).
Oct 06, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
309 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
