Question about Compaq (243890-001) 250-Watt Power Supply
Compaq PDP116P 250w power supply pinout - Compaq (243890-001) 250-Watt Power Supply
2 Suggested Answers
SOURCE: Power connection pinout
Here is a pin connection specification for the ac power supply (dual voltage adaptor)
>socket/plug for a Compaq TFT450 LCD Monitor that she
>supplied (edited for further clarity).
>The pins of the male connector (a PS2 mouse type connector) should be connected like this:
> 1 2
> 3 I 4
> 5 ^ 6
> GND GND
> 5V I 12V
> 5V ^ 12V
>For clarification - the male will be the end of your cable, and not the socket on the monitor.
>The I is the central polarising bar of the connector, and the ^ is the notch.
Posted on Aug 04, 2008
Monitor comes up with no signal, and fan is not going round on the tower I have a Packard Bellk Imedia 5061
Could be just about anything so let's go step by step.
Check power outlet for voltage. If you're using an extension, check that too. You can easily check by plugging in something else and see if it works.
Check power cable from pc to the wall. You can use a cheap multimeter for this. If it's a sealed plug then chances are that it's good unless the cable is perished or chewed up.
Check power supply. Easiest way is by shorting the power_on pin to ground. Go to http://pinouts.ru/pin_Power.shtml for more details. If it turns on it might be good. Check the pinout according to the voltages they should be giving you. If they're ok then it most probably is a fried motherboard. Last thing to check - trace the power button cable from the case to the mainboard, remove the connector and short out the 2 pins that are exposed. If the mainboard is good then it should start up. If it doesn't start up......well....most probably you'll have to change the mainboard.
Aug 13, 2012 | Work Station 250W ATX POWER SUPPLY (=...
I just need the pin out for the power switch connector
This link will show you the pinout for a UNIVERSAL power supply but it does not applyto Dells or Compaqs...
http://pinouts.ru/Power/atxpower_pinout.shtml
Feb 12, 2010 | Tyan Trinity 400 S1854 Motherboard
How to use ATX-250-12z SMPS with 24 pin
Chances are that 250w power supply is not going to power a motherboard with a 24 pin connector, but you can try.
You will need to purchase a 20 to 24 pin adapter cable.
Google Search Terms: 20 to 24 pin adapter
Oct 27, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Need the schematic to plug in the power connectors
This link http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm
is a great page for the standard ATX pinout and related info.
WARNNING dell's and some other psu's have a different layout.
If you look onto the power supply box, you will see a modle like
ATX130p3, google this with "pinout".
Aug 07, 2009 | HP Compaq Evo w4000 PC Desktop
Not sure about upgrading power supply
In many cases the additional 4 pin section slides up and off of the main power plug for use in your particular unit.
Feb 20, 2009 | HP COMPAQ Presario SR5410F Pentium...
Compaq dead after power company shutdown period
Sounds like a blown fuse in the psu, replace the unit and you should be good to go.
Nov 30, 2008 | HP ATX-250-12Z, ATX-250-12Z Rev. H1, HP...
> 1 2
> 3 I 4
> 5 ^ 6
> GND GND
> 5V I 12V
> 5V ^ 12V
Jun 16, 2008 | Compaq TFT450 14" LCD Monitor
Compaq (243890-001) 250-Watt Power Supply Logo
83 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
