Question about Avanti Fitness AT480 Treadmill
Power on but no reset
Will not reset or move
Cant reset car stereo
my name is larry i have a 1999 gmcyucon and it stuck in 4 hi,
Feb 19, 2014 | Cars & Trucks
Hard reset button
Go for hard reset
  • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
  • When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
  • When the LED lights in green, press the Stop/Reset button 4 times
Oct 23, 2013 | Canon MG5250 Printer
How to reset my z990 avil at&t tuch screen phone
You have 2 options to reset the device. One is through the Menu and the other is through the buttons on the device. Press the Menu Key > Settings > Privacy > Factory data reset > Reset phone > Erase everything.
Hard Reset-Power off the phone.
2.Press and hold "Vol+", "Menu", and "Power" key until the phone goes to recovery mode.
3.Use "Vol+" and "Vol-" to move the cursor up and down.
4.Move cursor to "wipe data/factory reset", press "Back" key to select it.
5.Now move cursor down to "Yes - delete all user data" and press "Back" to select it.
6.The data will be erased.
7.The cursor will be on "reboot system now" at the end, so just press "Back" key to reboot the phone normally.
Jan 12, 2013 | ZTE Z990 Avail At&t Black Android Touch...
Screen E:91:01 what does it mean?
Most probably the issue is with the lens. Service is required if the issue persists after power resetting.
Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder.
2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder.
2. Disconnect AC power adapter.
3. Remove the battery pack.
4. Move the POWER switch to the CAMERA position for 15 seconds.
5. Move the POWER switch to the OFF position.
6. Reconnect the AC power adapter or reinsert the battery pack.
7. Turn on the camcorder.
If the issue persists after following all the steps service will be required.
Jun 23, 2012 | Sony Handycam HDR-CX360V Camcorder
How to reset MP 198 printer
  1. Start with printer OFF
  2. Hold down STOP/RESET and then hold down POWER
  3. Release STOP/RESET (don't let go of the power just yet)
  4. press RESUME twice, then release POWER
  5. let green light blink until printhead has finished moving.
Mar 01, 2011 | Office Equipment & Supplies
How do u reset jvc camcorder
1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the A position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.
Nov 30, 2010 | JVC GR-SXM240U Camcorder
MASTER RESET CODES FOR SONY ERICSSON
Here are the Master Reset codes for your phone.
Master Reset / Codes
Accessing the Service Menu - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key.
Checking Firmware Version - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key, press 1 key twice.
Show IMEI # - press * key, press # key, press 0 key, press 6 key, press # key
Manual brightness adjustment - While in camera mode, press and hold * key and move joystick to lower brightness, press and hold 0 key and move joystick to increase brightness
Quick ScreenSaver - Pressing # and * at the same time
Show screensaver and lock keypad - press * and lock keys
*#0000# - Reset language back to english
Hard Reset -Hold power for 10 seconds
May 28, 2009 | Samsung SGH-D500 Cellular Phone
Computer won't powere on, green light flasing on back.
HI...the motherboard of your computer has a BIOS which needs to be reset. By resetting:
1. Turn off the computer and unplug the power cord
2. remove the button battery(CR2032) on the motherboard
3. right next to the battery has a jumper
4. move the jumper over by one pin and wait 10 seconds.
5. move back the jumper and put in the battery
6. finally, power up the computer
Hope this helps
May 18, 2009 | HP Computers & Internet
Hello please help
Try re-setting the printer like this:
Canon MP150
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
Jun 06, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Toshiba e310 no reset
When it is reset the screen is just a series of vertical lines or just plain white. if it beeps it isone quick beep.
It appears to do things when you move the stylist over the screen yet can't go to the main screen.
I have followed factory reset (switch off then on), (reset power till screen on then release power), (disconnect power plug from battery to board). NOTHING worked
Jan 24, 2007 | Toshiba e310 Pocket PC
Avanti Fitness AT480 Treadmill Logo
20 people viewed this question
Top Avanti Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
Bill Boyd
Are you an Avanti Exercise and Fitnes Expert? Answer questions, earn points and help others
