Question about Gateway FPD1975W 19" LCD Monitor
Need info Can you play DVDs on this monitor by hooking it up to a stand-alone DVD player?
  • 1 more comment
  • lmkehew Jan 28, 2009
    The monitor input hookup is described as "DVI-D with HDCP input" - does that mean that the standalone DVD player will have to be digital to work?
    So, in order to get this thing to work, I will need an adaptor and a set of speakers, right? I am assuming that there is a separate input hookup on the monitor to plug in the speakers (I haven't taken it out of the box yet because this is supposed to be a gift and, besides, I am a technical cripple)!!! Thanks much for all the help!
  • lmkehew Jan 30, 2009
    Thanks so much for all the help!!!
  • 31 Answers
Yes and no. wou will need a vga to RCA video adaptor, then you will need to get something to play the sound through. after thats sorted out it should work. I use my monitor to play my xbox360 using external speakers
Posted on Jan 27, 2009
  • Robert Jan 28, 2009
    DVI-D is just a fancier version of vga, it supports a better picture quality, with the right cables the same princple applies and it should work
  • Robert Jan 29, 2009
    assuming that the monitor has speakers built into it the you will need 3 adapters. A VGA to RCA video adapter, a DVI to VGA adapter, and a Stereo RCA to Stereo Headphone jack. If the monitor does not have speakers, you can get a cheap set (or what ever you budget can afford) with a RCA stereo to Stereo Female headphone jack
My home theater system plays cds but will not play dvds, what can I do to fix it, makes a scratching noise when i put dvds in it, but plays fine with a cd.
There is something wrong with the DVD drive assembly inside. If you're brave, take it apart and check on what is making the noise. Also, try using a q-tip to clean the laser head if it's accessible.
If that doesn't help, it's time for a new DVD player.
This is why I always recommend people buy a home theater system without a DVD player built in. The DVD player is the weakest link, and stand alone DVD players can be purchased for as little as $25 depending on if you want upconversion or not.
If you cannot get the DVD player working in your surround system, just replace it with a stand alone DVD player, if you can, check to make sure there are audio inputs on the back of the receiver. If there are no audio inputs on the receiver, you will have to get the entire surround system replaced. If so, purchase a separate DVD player and surround system.
Jan 13, 2010 | LG LH-T754 Theater System
When I record to dvd I can't plan on any other DVD player - can play on the toshiba dvr but nothing else?
Have you closed the recording? If the recording is not closed out, you will have trouble playing the DVD in other players.
It could also be that your DVD player you are trying to play on is too old or not designed to use burned DVDs. I also have trouble playing some burned DVD's in older DVD players, it has to do with how the recording is done, and there is nothing you can do about it. For example, I have a Sony 5 disc changer that came with a surround sound set up... nice DVD player, but will NOT handle DVDs burned on stand alone DVD burners or burned from a PC. It reads the DVD, and displays on the front of the player that it is not a DVD, and shows nothing on the TV.
Jan 01, 2010 | Sling Media The Slingbox Pro
SAME old! JVC files mod, have converted with prism to avi in the past, with success. Now DVD player says (once) cannot read (next time) not compatible. using DVD-R
Are you talking about a stand alone dvd players?
If you are talking about a stand alone dvd player, that is correct they do not player .avi extension file. I know some portable dvd player can play avi extension files.
all avi extension files needs the right audio and video codec to be player. All stand alone dvd players does not and can not detect codec for you.
On the issues of dvd-r brands, Some stand alone dvd players can only play dvd+r type dvds. ck your brand of dvd disc and players, make sure they are complatible with each other.
Nov 04, 2009 | JVC Everio GZ-MG77 Camcorder
Need to learn how to Finalize DVD's on my laptop
Burning DVDs requires that you create a .iso file to burn to the disc. Once this is done you can use a program such as ImgBurn to write it to the DVD and it will then play in most all stand alone DVD players.
Nov 02, 2009 | Dell Inspiron 1545 Notebook
I have burn a DVD video using Cyberlink DVD Suite using LG super multi DVD Writer, but once the burn is completed my stand alone DVD players is not able to read and throws message as No Disc - i have...
There are many DVD formats DVD- DVD+ DVD-ROM heck even blueray is a different DVD format.,Now see if you can find any paper work for your DVD stand alone and see what is compatible with it.
The only other thought it may be, in your burning program you can select to have the DVD play only on the computer you make it on...see if that is checked
and if it is make so DVDs can play in all players.
So to recap: a compatibility issue or a proprietary setting for your computer only.
hope this helps, please leave rating, thank you
May 11, 2009 | CyberLink PowerDirector 3 for PC
Dubbed DVDs will not play
You have to use the Magnavox dual to finalize the discs, and then they should be able to play on other players. I don't have a manual for that exact recorder, but in general you would go to the Settings Menu of the DVD player --> go to Disc Edit --> and then select Finalize - the exact pathway might be a bit different on that particular recorder. Once you have finalized one of your discs, try it on another DVD player and see if it works. Good luck!
-Tha Mp3 Doctor
Feb 15, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Does a Philips CDRW/DVD SCB5285 on a laptop burn movies? If not then can I buy a stand alone dvd burner to hook up to it? Thanks for any help and input.
Thank you for getting back to me about my question. I found out that if my DVD is a DVD/ROM it does not burn DVDs. I am told that I can get a external DVD burner to Burn DVDs.
Thank You Very Much
Dan Connery
Feb 04, 2009 | Rio Televison & Video
Our Sony DVD player will not playimported DVDs from the UStates
1) those DVDs are coded in Region 1(Canada, United States; U.S. territories; Bermuda)
you will have to change the region code on the dvd-rom to region 1
2) if you bought the stand alone DVD player in the U.S. it will play region 1 dvds and nothing else(some dvd players will play region code 1-6)
3) to change the code in windows vista you'll have to go under the drive property's in the device manager go to the dvd region tab and set it to what ever the number on the back of the dvd is WARNING you only get 4 changes before the drive locks you out permanently then your stuck with what ever number you put in on the 4th try you've been warned
windows xp/2000/98/me
you'll have to change the region code from your software player again your limited on how many times you can change the region code before you have to reinstall the dvd player software
Feb 02, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Toshiba dvd-video recorder
Your monitor may need adjustments to color,or it may be going bad.Try to hook up a different one,if it still the same way,maybe the computer it self,call teck support.
Oct 23, 2008 | JVC XV-N33SL DVD Player
Gateway FPD1975W 19" LCD Monitor Logo
61 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
