Question about Electric Mobility Rascal Scooter Wheelchair Batteries
I have a Rascal scotter, Model #OB7, serial #80140. the key was taken apart and need to rewire it to fix it.
100 110 220/240 VAC. Hampton Engineering Mobility Ltb
5 Suggested Answers
gewiz
  • 1271 Answers
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
Posted on Jun 13, 2009
  • 13 Answers
SOURCE: I am looking for a user manual to download for an
A Manual can be found here hope its the correct one, if i can be any furthur assistance please email me rick @ lxrixta.co.uk (remove the spaces!)
Posted on Jul 01, 2009
bduxbury
  • 4108 Answers
SOURCE: what type of batteries does this model take?.jb.
you need 12v 33ah sealed deep cycle battery most likely it may need two batteries any thing above 33 amp hours would also be ok. A higher Ah the longer the batteries last. This information on the type of battery is from the user manual.
http://www.hardwarexpress.co.uk/rascal-388-mobility-scooter-battery-1949-p.asp
Any battery type store should be able to supply this to you .
Posted on Feb 10, 2015
bill91074
  • 401 Answers
SOURCE: Where can I get repair on a Rascal Little Rascal made by Electric Mobility
You can use my app to help you find out how to repair your Rascal Scooter Doctor App , If you are looking for a technician in your area then try Mobility Parts and Service Official Rascal Parts Supplier .
Posted on May 13, 2016
WHERE CAN I GET A REPAIR MANUAL FOR RASCAL MODEL 245
I work on them all the time, never saw one come apart without my help! Is the motor coming apart? email me at bill@strege.com, or for more info on Rascals goto Scooter Doctor App
Oct 09, 2015 | Health & Beauty
Rascal 230 wiring diagram
Check the multi pin connector on tiller and where it connects under the seat between the batteries. Most common problem.
Oct 09, 2014 | Electric Mobility Rascal Scooter...
I purchased a ceiling fan fifteen years ago and the motor is going out. I'm not sure what the serial number is, but I found CS-5201. Is this your fan and can I buy a replacement motor.
The motor is pretty much the entire fan and I have taken apart many of them but I do not see any fees able way that you would be able to get it back together if you could get a motor. I would make sure that the problem is not just the speed capacitor or the speed control switch, witch are fairly simple to replace.
May 30, 2011 | Hampton Bay 13087 70450 Carousel II...
Do I need to oil my ceiling fan ocasionally? I can't find a manual, so I don't know the model or serial #. I do have the orig order form from Home Depot, from '04. this fan is Hampton Bay 54" windward...
No the bearings are sealed, and not designed to lubricate. They can go bad, and if they do it is possible to remove the seals and re-oil/grease them. Sometimes this helps a little but not always. If you try to lubricate them without disassembling the fan, pulling the bearings, remove the seals, most likely whatever you try and squirt in their will just attract dirts and make things worse. getting to the bearings, usually means taking things apart that were not meant to come apart. So, the short answer is usually if they go bad the fan is shot. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 01, 2010 | Hampton Bay 04345 Cruiser Ceiling Fan
I just got a pre owned rascal 329le scooter and i need to replace the tyres< but i can not read the size on the original tyre as they scuffed and badly damaged
Your best bet is to call the manufacturer and give them the model and serial number if available. They will give you the tire and wheel size and a local dealer to purchase from. The Rascal is manufactured by Electric Mobility at 1-800-MOBILITY.
Aug 25, 2010 | Health & Beauty
I am looking for a manual for the Proctor Silex Bread Maker 80140
Hi
Thanks for using FixYa. You can check the Use and Care Manualfor Proctor Silex 80140 from the link---
ProctorSilex Bread Maker 80140 User Manual
Please do rate the solution and revert for furtherassistance.
Thanks
Rylee
Oct 09, 2009 | Hamilton Beach Kitchen Appliances - Others
My tro bilt model tb320bv gas leaf blower will not run at full th
The carburetor may need to be taken apart and cleaned or rebuilt. If you haven't taken one apart before your best bet is to see if you can get an after market carb for it, that would probably be the cheapest way out.
Jan 12, 2009 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Reassembly of Auger Housing
If you go to www.mtdcanada.com you should be able to find aparts breakdown for your machine which will be helpfull in puting it back together.You will need your model and serial # to find your parts breakdown. The breaedown wont tell you how to do it but it will give you a good idea. if it's not helpful the if you post the model and serial # here then I can see what you will need to do.
Dec 21, 2008 | Toro Blowers Rake and Vac - Electric...
Electric Mobility Rascal Scooter Wheelchair Batteries Logo
327 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
