Question about Drills
Need 2 belts one is HB28-3 and the other is HB22-3 and bearing part 6205 for a Duracraft model 1600 drill press
I believe this was purchased at Sears in 1983.
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: how to remove chuck from drill press
I just looked at a breakdown for this tool and it is not that clear. But to get an owners manual you can go to Searspartsdirect.com and type in your model number and look at the same schematici I did and also order a manual for about 7.50. Usually though on a drill press like that it would be a morse taper. Do you see a slot cut thru the spindle on both sides, if so there should be a tapered key that came with the unit. In that case what you would need to do it put the key in the slot and tap it with a hammer to remove the adaptor and chuck. Let me know if I can help further
Posted on Jan 03, 2009
SRF518
  • 232 Answers
SOURCE: Hi I'm looking for a part for a drill press
check out this url:
www.jalopyjournal.com/forum/showthread.php?t=237685
Posted on Oct 20, 2009
al_kupchella
  • 843 Answers
SOURCE: i need a chuck wrench/tool for a duracraft drill press
Are you talking about the chuck key? That's the little wrench with a collar of gear teeth on it.
There are only a few standard sizes plus a couple of odd-balls. Last time I looked, Sears carried a good selection. If you have the old one, take it with you to the store. If you don't have the old one, find a way to measure or approximately measure what you need. Another chuck key that doesn't fit can be a useful reference. If you can find something (maybe a drill bit) that is a close fit into one of the three holes in the chuck, that can be useful too.
Posted on Jan 19, 2010
puertobori
  • 7733 Answers
SOURCE: I need a return spring for DURACRAFT DRILL PRESS
Go to eReplacementParts.com : Power Tool Parts and Tool Repair and find parts and diagrams very useful.
Posted on Nov 09, 2010
Looking for recoil spring for a duracraft floor model drill press. model # 45160. can you help
Woodstock International's Shop Fox machinery line has gradually proven itself to be one of the top brands for woodworking and metalworking equipment in America.
more details Consider an Ultimate Shop Fox D4088 Drill Press review
May 27, 2015 | Drills
What is the size of the replacement chuck key for the Duracraft DP514?
The 1/2 inch is the max size drill that will fit into the chuck. There are only a few different key sizes, and sears sells them in their tool area. Easiest thing to do is find the size of the hole the chuck fits into by using the back end of a drill bit that fits the best. Measure that drill bit or take it with you to the store. You might find two different size keys with that size pilot hole, or maybe only one. Good luck!
Dec 27, 2012 | Drills
I need a 5/8" chuck key for a Mod.1600(1984)Duracraft drillpress
There are perhaps half a dozen sizes of chuck keys. Sears carries them. You can measure the size of the pin by finding a drill bit or bolt that fits well and taking that to the store with you. You can approximate the size of the teeth by using a piece of paper and forming it over the chuck and using a pencil to rub over the teeth. Put a hole in the paper with the bolt or drill bit to capture the radius from the pin to the teeth. If you find a couple of close candidates, buy them both. Sears will take the other one back. Good luck.
Jun 22, 2010 | Craftsman Drills
I need a chuck wrench/tool for a duracraft drill press
Jan 17, 2010 | Drills
check out this url:
Oct 20, 2009 | Drills
Belt tension lever repair
Go to Sears Parts Direct.com and type in your model number it will direct you to 4 different views of this tool. I believe you want figure 2 and it looks like there is a hex nut that needs removed, but check this out first. Hope this helps and Good Luck. Dave
Dec 12, 2008 | Delta 15 331 15" 115/230V Variable Speed...
Drills Logo
32 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
