Question about Motorola Mobility S305 Bluetooth Headset
My motorola s305 connects and disconnects constantly
I use the headset with my MacBook Pro and it used to work perfect, but this week it has been terrible. When I listen to music I just can't hear to a complete song without cuts and when trying to make a phone call it connects and disconnects constantly, just like every 5 seconds. Whenever there is a system sound the headset makes de reconnection sound.
Bh-503 audio cutting while listing music on my mobile
  • well i had an experience the same as you before, i think it's defend to your headset if your using a bluetooth headset or a cabled headset because if your using bluetooth headset and you're walking while listening you will hear the music cutting
Jan 24, 2013 | Nokia BH-503 Bluetooth Headset
Can't hear music with headphones?
go to system preferences then click on sound, then make sure the "use audio port for" is set to sound output.10_19_2012_4_02_12_am.png
Sep 30, 2012 | Apple MacBook Pro Notebook
I installed a software called Hear on my T420 laptop after a while i uninstalled it but since then i have problem with sound! when i play music i hear the sound from the speakers, it's normal but
Use the SYSTEM RESTORE utility to go back to a certain date that you think is in its perfect condition, say 2 to 5 days ago will do. Everything will be restored except data or work files. Good luck
May 19, 2012 | Lenovo ThinkPad T420 Notebook
I can't listen music through my bluetooth headset with samsung
can you hear the incoming voice?or can you talk while call is coming?if no then there is a problem in your bluetooth.otherwise there is a problem from your phone check it first.best of luck.
Feb 10, 2012 | Samsung Wave S8500 Smartphone
Hi there, I got an Apple MacBook Pro, OS 10.6.7 and recently got problems connecting to my wireless internet at home. I've got no problems at all connecting to other wlans (at work, at friends'...
So you're knowledgeable, good. Do you have the SSID broadcasting or not? Do you have WEP or WPA, etc active? Can you find the network you are trying to connect to under preferences on your MacBook Pro? Does your network show up? Either way, delete it and start over. If you re-set up your network and it still doesn't find it, but the other machines in your house work wirelessly, it is still a configuration issue. Do you have your wireless network as the default network to find? Do you have a help desk that you can call at your workplace? Give me more details and i'll continue to try and assist.
Jun 10, 2011 | Computers & Internet
How I can listen music through headset
Your Plantronics Voyager Pro Plus is equipped with A2DP which makes the streaming of music in the headset possible. However if the phone you have does not have that application it won't happen.
Good luck from Headsets Direct!
May 26, 2011 | Plantronics Voyager PRO Bluetooth Headset
Cant hear music through my LG HBS-200 Bluetooth Stereo Headset
I have the same problem with my HBS-250. It was working fine on my iPod Touch. It worked the first couple of weeks on my iPhone 4 then stopped playing music. Phone funtion works. No music or podcasts or streaming from the web
Sep 12, 2009 | LG SGBS0001606 Bluetooth HBS-200 Stereo...
Ipod Sound Quality Terrible
Go into settings, EQ, and try out some of the EQ settings.
Jun 03, 2009 | Apple iPod classic MP3 Player
Cant listen to music on my Blackberry Pearl using HT820
RIM has a new OS for the 8100 pearl (OS 4.3). This OS supports A2DP streaming which is necessary for listening to music with bluetooth headphones. The OS is out in beta version now and supposedly available on bit torrent. I hear that AT&T will release the OS for their phones in April or May.
Nov 06, 2007 | Motorola Mobility HT820 Wireless / Cable...
Motorola Mobility S305 Bluetooth Headset Logo
83 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
