Question about Stuhrling Original Mens Monticello Swiss Quartz Watch
How do i adjust the mesh band on my Stuhrling Original Monticello
How to adjust band on watch
Hi, you will have to go on the internet and type in " how to adjust a band on a stuhrling watch you will find your answer.
Dec 31, 2015 | Stuhrling Watches
Location of repair center in U S for Stuhrling watches?
You can take your Stuhrling Original watch to any watch repair shop for repairs. Or you can package it up and send it to: Stuhrling Original, LLC, 449 20th Street, Brooklyn, NY, 11215.
Jun 27, 2014 | Stuhrling Watches
Where do I get the screws for a Stuhrling 142A2.PK2 Mens Pocket Watch?
Try a watch repair shop or contact Stuhrling Original, LLC at 449 20th Street, Brooklyn, NY 11215, (718) 840-5760.
Jun 05, 2014 | Stuhrling 142A2.PK2 Mens Pocket Watch...
Skagen replacement band
I am facing the same issue as you. I have a Skagen 311LTRB watch without a band. I purchased the watch without a band, so I don't even know what the original band looks like.
It seems strange to me that Google doesn't even find that model of Skagen watch when you search on the model number. Makes me wonder if the watch is fake or real.
What I did was purchase an 18 mm mesh band and two pins from the following seller on eBay: "BandFever" / "18mm SILVER MESH WATCH BAND,COMES WITH 2 SPRING BARS". It only cost $12.95 with free shipping.
After installing the band, I am now able to wear the watch. And it feels very comfortable with the mesh band. However, it looks a littly dorky because there are overhangs on each side of the watch where the bands attach. I keep wondering what the watch appeared like when it was new with its original band.
Aug 27, 2013 | Watches
Have a Titanium Skagen watch #311LTRB and would like a replacement band. Can you assist?
Wish I could paste an image of the watch, but that doesn't seem to be allowed.
I have the Ladies Wall Street watch with the beige color leather strap. A red velour tracksuit rubbed some red on the band...how can I get it off? Thanks for your help! NancyMacNeill
Hi nmac1009
The most common way to remove any coloured spot is to gently rub it with some spirit or petrol.
You can take a earbud. Dip it in gasolene or petrol.
Squize it.
Then gently and very carefully rub it on the red spots.
Note: Be very careful while doing this.
Better you first check that it does not remove the original color of the leather strap.
Then only go ahead.
Hope this helps.
Jan 28, 2011 | Stuhrling Watches
Received Skagen watch Order No: W256417 today. Mesh Band is too long for me. I do not understand step 2 of instructions Ray Reeves
Ajusting the Clasp - Skagen signature mesh bands are easily adjustable in just three simple steps:
LIFT - SHIFT - PRESS Lift the slotted clasp, Shift the adjustable buckle to the desired position (make sure the clasp is set in one of the indentations on teh back of the band), Press the slotted clasp closed.
Aug 18, 2010 | Skagen Watches
I just bought a skagen stainless steel mesh band watch. I am trying to adjust the band to make it shorter. I have the piece the moves open, but I cannot figure out how to get it shut again.
http://www.skagen.com/service/watchInstructions.fx#adjustment
your watch has the skagen signature mesh band. its actually very easy to adjust once you figure it out all you need is a small screwdriver.
Dec 21, 2009 | Skagen Signature Mesh watch
Size watch bracelet
your band is Skagen Signature Mesh
Dec 26, 2008 | Skagen Watch
Adjusting mesh band
Take a small flathead screwdriver, or maybe a metal nail file and pry up the catch.DO NOT pry up by placing the tool on the rod used for hooking the clasp side to this side. Just stick in the metal piece that is folded over ( it should have a little notch in it) and pry it up. If you still don't understand I will be glad to send you a picture later on today. PLEASE let me know either way!!
Aug 11, 2008 | Watches
Stuhrling Original Mens Monticello Swiss Quartz Watch Logo
272 people viewed this question
Top Stuhrling Watches Experts
ptpumpman
 Mikey
Mikey
Are you a Stuhrling Watch Expert? Answer questions, earn points and help others
