Question about GE Spacemaker JVM1640SJ Microwave Oven
Spacemakerxl1400 suddely stopped heating,all other functions are it due to some small problem
  • 7 more comments
  • ksrmd Jan 27, 2009
    what is the solution
  • wild777 Jan 27, 2009
    i have the same problem
  • sterling3 Jan 28, 2009
    I have same problem. Burnt electrical smell (like a bad ballast) Lights work, table rotates and controls seem fine. No heat.
  • Anonymous Jan 30, 2009
    Tried to heat up something then made a loud noise - since then it does not heat anything. Function electronic pad is working and microwave noisier than usual.
  • Anonymous Jan 31, 2009
    GE Spacemaker Microwave - Model # JVM1430BD002
    It doesn't heat up the food, but every thing else works.
    No unusual sound or smell.
    Any idea what might be wrong?
  • harrychapman Jan 31, 2009
    Same problem as others have mentioned - everything works fine except the microwave no longer heats up the items in the microwave. - No smells of any sort - everything else seems fine.
  • azdi Feb 01, 2009
    Exact same problem. Everything else works, no strange noises, smells or indications of a problem; just no heating.
    Model #: JVM1460AA 001
    Has anyone gotten a solution or determined whether it's just time for a new one?
  • Anonymous Feb 02, 2009
    JVM1650 with the same problem. Everything works but it doesn't heat anything.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
    What is the model number?
GE Spacemaker model XL1400 not heating. Everything else works on it, but no heat. What could be the problem? Can it be fixed reasonably?
Posted on Feb 01, 2009
Everything still functions properly on whirlpool microwave model number KCMS185J88 - 3 but it won't actually heat. What may be the problem?
There are usually two separate circuits, one for the magnetron(which does the heating), and one for other functions like fan, light, or turntable. A number of things can cause just the heating to quit. The magnetron circuit has a fuse and it can blow, sometimes for no apparent reason, and sometimes because there is a serious short, such as a shorted hi-voltage diode or failed capacitor. This circuit also has some safety interlock switches that stop the magnetron if they don't function properly for some reason. Because of the dangerous high Voltages associated with these devices, I recommend you take it to a qualified technician. The problems I described, are often not difficult to diagnose by a tech, and frequently, the parts are not costly either. I would take it directly to a tech at a shop to avoid an expensive house call. That way, if it is diagnosed as an expensive repair, you can opt out and cut your losses right there. Or you may get lucky and pay a small labor charge and another small amount for a part.
Dec 13, 2015 | Microwave Ovens
Daewoo KOR-1N0A microwave oven not heating
This is most likely the fuse in the high voltage magnetron circuit (that is the microwave generator). This fuse is usually inside an inline plastic case that can be opened for replacement. Don't attempt this unless you have some experience and can work from just this clue. Otherwise take it to a professional repair shop.
I would guess it is only worth repairing if you think this may have been caused by overloading the oven (i.e. putting something metallic in the oven). If not then the fuse may have blown due to another problem and you would be better off to buy a new microwave oven.
Apr 04, 2014 | Microwave Ovens
CATA MC25SS microwave not heating
Usually when a microwave's fuse blows, it will be dead, not partially functioning.
It may be a bad door switch or mount.
(Anybody in the home opening the door while it's cooking?)
See our help file on door switches here.
Feb 25, 2013 | Microwave Ovens
Carousel stopped turning
see this causes and fix it. God bless you
ough the carousel is usually driven by a small motor that's unrelated to the heating function of the microwave, the microwave cabinet needs to be opened to repair it. So we recommend that you seek the assistance of a qualified appliance repair technician. Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly
Sep 24, 2012 | Tappan Microwave Ovens
Maytag mmv 1153aab microwave on start up started then suddely stopped no power whatsoever to unit now normal checks including internal fuse ok
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Nov 25, 2010 | Maytag MMV1153A Microwave Oven
My Danby Diplomat 1000 Watt microwave suddely stopped workinmg (display went dark, no door light, nothing). I'm thinking it could be a fuse?
Oct 26, 2010 | Danby DMW1406 1000 Watts Microwave Oven
Over Stove Microwave, all works except doesn't heat
Hello. The problem you are having with your microwave is due to either a shorted rectifier or a shorted magnetron.
Regards, Joe
Dec 23, 2009 | Microwave Ovens
GE Spacemaker XL1800 does not heat. All other functions appear to be working normally, the light comes on and the turntable functions. When turned on, it makes a humming noise slightly louder than normal,...
Possible bad heating element, You should remove the cover of the unit and look at the heating element with the power off. Until you get your problem resolved I would recommend not to even turn it on due to the fact that you are unsure what is going on and you smelt some burnt smell. Just for safety until you fine the problem
Feb 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Nothing works except the display
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Dec 25, 2008 | Panasonic NN-S961 Microwave Oven
GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Sep 20, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
713 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
