Question about Gateway FPD1975W 19" LCD Monitor
FPD1975W monitor issues
My FPD1975W monitor goes black after 4 seconds. I can turn it off and on and it will show up as a perfect picture and then goes black again. It is not even 2 years old. Anyone know what may be causing this?
  • 1 more comment
  • xxaana Jan 28, 2009
    Thank you for the prompt reply and it does it when either on HD cable or the DVI as I have it plugged in with HD cable into my HD converter box. When the AVI/DVI was removed, it still did the same thing through the cable box.
  • Anonymous Mar 13, 2009
    i ahve the same probelm, i also unhooked my 2nd pc which has a totally different set up and the monitor still acts up, its not he video card, drivers or power cord( tried 2 identical cords)
  • Anonymous Apr 18, 2009
    same here and it isn't the theft deterrent system
  • 6,784 Answers
Check your video card. it may be a bit lose in the port. Also, you should reinstall your video card drivers as well. make sure your monitor is plugged into the correct video card AVI/dvi input port.
Posted on Jan 28, 2009
This is the strangest thing I've ever seen. I have a Gateway FPD1975W TFT Monitor and its always worked great. The other day it went into a sleep mode via windows, and now it wont boot up the input...
Your monitor problem is causes by the power supply. What is happening is the power supply voltages are not stable, just enough to power the unit up. When you connect it to a video signal the power demands slightly increase and the power supply can't handle it. This is a very common problem with LCD after a few years of use. The issue with the power supply is the capacitors have started to fail. These parts are used to filter the output voltage and when they start to fail the outputs start rippling hence the problem you are having. Here is a link to a repair article that shows how to repair the Gateway FPD1975W monitor.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps you get back going.
BuddyMc
Sep 20, 2011 | Gateway FPD1975W 19" LCD Monitor
My dell monitor will only turn on for a few seconds then it goes black. it doesnt turn of it just goes black and I can keep doing it and it will keep going black.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Dell E193FP 19" LCD Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
My Dell Monitro goes black about 4 seconds after being turned on
Hi..there,
It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it.
Nov 12, 2008 | Computers & Internet
17" LCD Monitor - only works for a few seconds when turned on.
It seems to be an Inverter related problem in which backlight seems to be shiutting down.Is this monitor 3-4 years old???If so backlight of the panel could be an issue.
Feb 15, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Good picture for 30 seconds then screen goes black with a faint ghost of the image
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Picture shows up for about 3 seconds then the screen goes black
XEROX 19" (XG92D) 5 MONTHS OLD...IT GOES TO WHITE WHEN WINDOWS TELLS IT TO TRUN OFF AFTER 2 HRS...IT GETS HARDER TO COME ON EACH TIME IT IS TURNED OFF. I TOLD WINDOWS TO NEVER TURN IT OFF. IF THE POWER GOES OFF I MUST TURNED IT OFF AND ON MANY TIMES, THEN IT COMES ON. I THINK IT MAY NOT COME ON NEXT TIME...
Sep 26, 2006 | Xerox XG-91D 19" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
571 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
