Question about 1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch
What causes No Spark in 1997 Chevy?
Does not start
  • Danno5691
    Danno5691 May 11, 2010
    None at all? or certain cylinders? Possabilities, crack rotor, bad coil, bad coil to dizzy wire, bad rotor, no power to the distributor.
    Problem Solver:
  • 10 Answers
Coil pack or the distruber wont fire some where in that general area
Posted on Jul 09, 2009
I changed my spark plugs a sensor an fuel pump on my 1997 chevy tahoe it still dont wanna start
The VERY 1ST thing you must do is to have the engine's computer control computer (PCM) scanned for fault codes, almost anything that would cause a no start will set a fault code. Buy or borrow a OBD2 code reader and read the codes.
Jul 16, 2016 | Cars & Trucks
What causes my 5.7 to miss and backfires while accleration
Many things can cause this. If there is a check engine light have it scanned. It could be bad spark plugs or even a cat
Oct 10, 2014 | 1995-1997 Chevy Tahoe Ignition Starter...
I have a 1997 chevy lumina that won't start
check your battery first, then check your ignition switch, then check your spark plugs and wires.
Jun 29, 2013 | 1997 Chevrolet Lumina
My 1997 chevy 2500 cheyenne is getting good fuel to manifold but not starting
Fuel pressure should be around 50psi. Make sure that the injectors are receiving a signal from the computer. Does it run if you spray starter fluid in it?
Apr 10, 2013 | 1995-1997 Chevy 3500 Truck Ignition...
1997 chevy venture hard to start
"hard to start" is a very vague description of the problem. There are MANY things that can make an engine hard to start - ranging from a weak battery to a bad fuel pump, to worn-out spark plugs or a plain, worn-out engine...
The only "solution" I can offer at this point, would be to recommend doing some diagnostics to determine at least which system in your vehicle is the cause of the hard starting.
May 25, 2012 | 1997 Chevrolet Venture
Resealed intake manifold on 1997 chevy tahoe.truck now is a no start .good fuel pressure. timiinng dead on,good spark. any ideas
make sure oil sending unit is plugged in check for vacuum leak between two piece manifold pull spark plugs after trying to start look for wet gas foul
Feb 21, 2010 | 1997 Chevrolet Tahoe
1997 chevey astro van won't start
Chk. all fuses, there is a fuse for injectors, If no spark at plugs chk ignition fuse and switch, and chk. fuse for e.c.m. Can't help with diagram. Parts dept. chevy dealer will print you one out.
Feb 14, 2009 | 2000 Chevrolet Astro
1999 chevy venture will not start could it be the fuel injector or what could be the problem?
There are many things that can cause a vehicle to not start.
1. No spark to spark plugs
2. No fuel injector function
3. Low / no fuel pressure.
And there are many things that can cause a loss of either one of these things. A bad fuel injector would not cause this.
Dec 12, 2008 | 1997 Chevrolet Venture
1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch Logo
282 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
