Question about Philips Magnavox 51MP392H Rear Projection Television
I need the screen cover part number483538047059
I was told they no longer make it and the tv is very bright and hard to see without it. It is the thin acrylic like piece with thin black lines.
  • 11,896 Answers
Www.TV-Armor.com
ZAGG.com/invisibleSHIELD
Clarivue.com
http://www.tristatemodule.com
Posted on Jan 27, 2009
The background of my Kindle Fire HD has gone dull and I am having difficulty moving around the screen
Have you tried to go into your settings to re-adjust your lighting? The way to do that is go to the top of your screen and with your finger pull downward and this will show you different settings and one of them is brightness. If you tap on that you are able to control how bright your screen is. As for the problem of having to tap hard to do anything; do you have a screen protector on your screen??? That is a thin covering that adheres to your kindle screen to protect the screen from scratches, etc. What I have found is when my kindle has that problem it is because my screen protector needs a desperate cleaning. It just happened to me recently, I took a cloth and a little bit of windex sprayed on the cloth and cleaned it. I don't recommend doing that on an unprotected screen. I did it because my screen is protected. Once I cleaned it up I no longer had the problem. If none of these work I would contact Amazon or where this was purchased from as it should be covered by a warranty
I hope this helps.
Mar 06, 2015 | Amazon Kindle Fire HD
TV screen has a thin horizontal line in center
this will only help until the next time it is out of alignment but if you slap the side of your tv about where the line is it should straighten out but there is no telling how long it will stay straight......My sons tv was doing that and i had a tv when i was young that did it that is what my mom told me to do and what i told my son to do and it works.... the problem is an alignment or conection problem from dust most likely.
Jul 11, 2012 | Sanyo Televison & Video
I am trying to help my neighbor. She has a Sanyo flat screen tv Model DS20930. The picture she gets is a thin line across the center of the screen.
Hello
Set the brightness, contrast and colour control of that TV to minimum. Watch it in a dark room whether ther are thin white lines across the screen, at about an inch apart, from bottom to top of the screen. If there are lines, that TV needs screen control adjustments. That is, now the screen voltage given to the picture tube went high to some reasons. If you have confidence that you can adjust it, I will guide you.
Open the back cover of that TV. Locate the LOT [Line output Transformer], usually one red thick wire is connected to the top of the picture tube with the help of a rubber ****** and clip. In most TVs it can be located and can be seen as the back cover opened. There are two variable control, fitted, integrated to LOT. Normally the upper one is marked as focus, and the lower one is marked as screen. You shoud adjust this control to avoid these lines.
It is a live service, that is the TV must be switched on during this time, and take causion in every respect not hurt by yoursef and the TV. Keep the children away from you, and an other adult person beside you is better. A liitle turn counterclockwise will remove this problem.
Oct 19, 2010 | Sanyo DS20930 20" TV
Can a home mechanic easily change a 1997 Eldorado's spark plugs and wires? Is there anything I need to know - good/bad, hints, etc?; any advice please. I was told this is too difficult to do with...
NORTHSTAR 4.6 ENGINE REMOVE INTAKE MANIFOLD SERVICE COVER FROM THE ENGINE.SPARK PLUGS IN THE VALVE COVER BUT THE SPARK PLUGS NOT HARD TO CHANGE.YOU NEED A LONGER SPARK PLUG SOCKET OR YOU USE REGULAR SIZE PLUG SOCKET USING LONGER EXTENSIONS.YOU NEED SPARK PLUG BOOT PULLER.YOU NEED A UNIVERSAL JOINT.BESURE TO GET PIECE RUBBER HOSE 10 INCHES OR WHAT EVER SIZE PLACE HOSE OVER SPARK PLUGS FOR THE HARD TO REACH SPOTS TO HELP AID SPARK PLUG BACK IN WITHOUT STRIPPING THE THREADS.HOPE THIS HELP.
Aug 05, 2010 | 1997 Cadillac Eldorado
Acer aspirw 5100 brightness
1.The Function key (Fn), and the F6 key are pressed to turn the Backlight off to conserve power.
2.The Fn key and the right side arrow key, are pressed to increase Brightness.
You have a TFT LCD monitor screen. (Thin Film Transistor)
The LCD screen cannot be seen clearly without a Backlight.
The Backlight is a CCFL. Cold Cathode Fluorescent
tube. Resembles a small fluorescent tube used in residential, and commercial lighting.
The Backlight can go bad after time, and weaken.
If so, it will have to be replaced.
Sounds easy, it isn't.
The TFT LCD monitor screen is made up of layers. It's enclosed in a thin metal frame. Resembles a picture frame.
The frame is removed, after removing the LCD screen from the laptop's top cover.
The LCD screen transparent outside layers, are separated partially from the rest of the LCD screen.
The Backlight is removed out of the side.
This gives you an example of removing, and replacing an average Backlight,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Recommended job for a pro.
Dec 28, 2009 | Acer Aspire 5100 Notebook
JVC 32 INCH MODEL AV-32S585
is the bright line on the midle of the tv , if it's what u ia vertical problem also sometimes is the flyback , tv needs service ,
Apr 30, 2008 | Televison & Video
Sony kp-65wv700
I followed GuestUser/ Slinteriors advice and I fixed it. Open the front of the TV and there are 6 little nobs in the front. The botton 3 are what you need to adjust. from left to right the color controls are BLUE, RED GREEN. For the blue lines, slightly (I really mean very slightly) turn the botton left nob clockwise (right).
Mar 21, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Bright line coming in center of screen
Hi Shailendrar , your problem sounds like vertical collapse , the whole picture has collapsed into a thin , very bright centre line ? maybe the result of dry solder joints , does banging on the side of the tv temporarily fix ? if so , the circuit board requires inspection for bad solder joints . Alternately the vertical chip/transistor may be blown , replace as required. Cheers T
Dec 05, 2007 | Philips 19PR19 19" TV
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
Some part of TV has been fused causing no picture on screen , only bright green horizontal lines , not even video channel could be set ,cannot see menu on screen please help by specifying possible...
if the screen is real bright green with thin small white lines in it its probably a shorted picture tube. Or a shorted Green driver Transistor. Good Luck
Apr 12, 2006 | Thomson 14MG135 14" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
