Question about Echo Gas Blower 135 MPH390 CFM Blower PB250
Echo gas blower runs but stops when you pull on trigger
  • 666 Answers
SOURCE: Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
Posted on Apr 06, 2009
  • 7 Answers
SOURCE: Echo ES210 handheld blower. Just stopped running.
replace fuel ines and bushing , comes apart inside gas tank
Posted on Sep 11, 2009
  • 62 Answers
SOURCE: my echo pb2100 gas leaf blowers pull cord is loose
COULD BE THE SPRING INSIDE THE RECOIL NEEDS MAY NEED A NEW ONE
Posted on Sep 25, 2009
97F350diesel
  • 1326 Answers
SOURCE: I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
  • 5 Answers
SOURCE: i need a carberator for an echo back pack blower
Hey I recently found out that Echo will not sell to public directly.
its on the web site .you can purchase through their authorized dealers
only. I purchased a carburator for $42.71.look out for price mark ups
from diffrent dealers.shop around.Good luck.
Posted on Mar 28, 2010
Throttle handle trigger is stuck
see if the linkage on the carburetor is stuck
Nov 18, 2013 | Echo Backpack Blower PB-500T
I have an Echo PB-500T blower that won't throttle up. I bought this blower new about 3 months ago. Before this blower I had an exact same blower that gave me the same problem. I returned that blower...
Remove the in tank fuel filter and take it apart, the felt Echo uses on the filter clogs quickly. There is still a mesh screen filter in the assembly so make sure you put it all back together and reinstall the fuel filter into the tank.
Oct 02, 2011 | ECHO, Inc. PB-251C Handheld Blower
ECHO PB-500T - Stopped running and added gas fuel mix. Quit running again with full tank and now flywheel is stuck and I can't pull to start it. What is the problem?
My $350 Echo PB-500T seized up. I almost cried.
The solution was to drain the fuel tank.
  • Refill fuel tank with an 2-cycle Oli/gas mixture.
  • 40:1 =3.2 oz to one-gallon gas, do not use Alcohol base gas.
  • Remove the spark plug.
  • Pour approximate 1/8 oz 2-cycle Oli into the spark plug hole.
  • Remove the pull cord assembly (4-bolts)
  • This reviled the crank shaft-Pull cord bracket
  • I use a large monkey wrench to turn the shaft (CW) Clock-wise.
  • Complete approximate 20 revolutions.
  • Reassemble, but don't install the spark plug yet.
  • Complete approximate 20 more revolutions
    by pulling the pull cord.
  • Use q-tips to swab the top of the piston, as much as possible.
  • Install the spark-plug and crank, it will smoke for amount 7-10 minutes
Jul 30, 2011 | Echo Gas Blower 162 MPH 450 CFM Blower...
I have an echo p250 that just stopped running in the middle of use. I've taken it apart up to but not pulling the head off. Cleaned and rebuilt it. has spark has gas sometimes if I keep the trigger...
I have echo p403. Similar but not exactly my issue. Rebuild the carb if you didn't already. Alternatively, you can buy a new carb approx 35$. After parts purchase and your time, 35$ isn't to expensive. The carb uses a diaphragm that seems to melts over time and use. I'm not a chemist, I can only tell you what I found inside, the diaphragm was like jelly after 10+ years of use.
Nov 01, 2017 | Garden
Echo blower, squeeze trigger , no power
thier is a metel wire that connects the throtle control to the carburator check to see if the wire is disconnected at the carb or the ubder side of tye throtle control trigger.
Nov 18, 2010 | ECHO, Inc. PB-251C Handheld Blower
Sep 25, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo gt 200r trimmer not spinning
there is a cable inside the tubing shaft you must separate engine from tube to access
Jul 17, 2009 | ECHO, Inc. PB-251C Handheld Blower
Runs fine &then suddenly stops
IN the tank there is a intake tube on the bottem of that tube is a tiny filter. you can reach in and pull it out the tank enough to work on it.
It is clogged pull it off let it dry for a day and then blow it clean fron the gas line side OUT.
or echo sells tune up kits for 10 bucks at home depot. -Jeff Anchorage Small Engine.
Dec 24, 2008 | ECHO, Inc. PB-251C Handheld Blower
Echo Gas Blower 135 MPH390 CFM Blower PB250 Logo
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
