Question about Kenmore 41389 Electric Double Oven
GE DUTCH OVEN JKSO5BOW2BB MODEL 3.4 FREE MANUAL
How to set clock on GE DOUBLE OVEN STOVE MODEL #JB860SJ1SS
To set the clock on the JB860SJ1SS, press and hold the 9 and 0 keypads simultaneously for 3 seconds (or a bit longer). Then type the current time using the keypad. Press Start to save the current time. This is shown on page 13 of the manual; see item 7 Clock.
Sears Parts Direct has the manual available here: https://www.searspartsdirect.com/partsdirect/user-manuals/JB860SJ1SS-GE-ELECTRIC%20RANGE-manual . The direct link to download the manual is currently https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1508037L.pdf .
I hope this helps.
Nov 05, 2017 | GE Ovens
GE Wall Oven Gasket Replacement
If you cannot find this on the net, contact the GE Appliances parts supplier for your area and order the service manual. Usually these are not free. There is some not easy to do un-assembly required. For safety you'd be best to have a service call from an authorized GE service rep.
Aug 23, 2014 | GE JKP15 Electric Single Oven
Find artifact images
In cooking a dutch oven is the original slow cooker. Usually made from cast iron, and can be used on top of a wood burning stove, in a wood burning fireplace, over a campfire, or with coal/charcoal. Some have domed lids, while others have a flat lid with a raised edge (aka flagged lid) which is idea for holding charcoal above the kettle. This allows for heat both above and below the dutch oven. These are generally available in stores such as Cabela's, BassPro and others.
Dec 02, 2013 | Ovens
How can I obtain a manual for this oven-GE JT952SOK2SS
Click this link to obtain your manual http://www.managemylife.com/mmh/owner_manuals/4884/GE-Built-In-Oven-Electric-L0502248?brand_name_search=JT952SK2SS if you have any further questions or are unable to obtain your manual through this link message me back and Thanks again for using Fixya
Rick
p.s by clicking this link you will be able to download your manual for free just click where it says download above the document where it says click here to download Thanks again
Jun 01, 2011 | GE Profile JT952 Electric Double Oven
F-3 has appeared twice on our GE Elec. oven. Model JKP14WOV1WW
some GE f3 is a bad oven temp sensor. look inside its a metal rod look
Feb 13, 2010 | Ovens
Is there a user manual for GE Gas Range JGBS23WEH4WW?
http://genet.geappliances.com/DocSearch/Dispatcher try this web site. Or go to geappliances.com, then service and support at the top of the page. Then enter your model number and it will show you the manuals you can down load for free. Good Luck
Jun 14, 2009 | GE JGRP17 Gas Single Oven
How to self clean
Depending on the condition of the oven, it could take up to 4 hours.
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Here is a link for your stove:
GE JTP18 Manual
Directions are on page 23.
Dec 13, 2008 | GE Profile JTP18 Electric Single Oven
Kenmore 41389 Electric Double Oven Logo
42 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
