Question about Mitsubishi WD-62528 62 in. LCD Television
Lamp where do i get a lamp for my WD62528 and how much?
  • 2,336 Answers
Click here to find the lamp for your TV.
Posted on Jan 27, 2009
I have a mitsubishi projection tv. I need to replace the bulb. Does any one know the difference between a pure glare bulb and a osram neolux bulb? Which bulb is right product for my tv? Also, which bulb is...
When in doubt check with sites such as www.TvRepairKits.com - check their online store first then email them if they do not show it. In most csases OSRAM is a great lamp...nore sure about pure glare...
Feb 22, 2013 | Philips 915P028010-P Projection TV...
My mitsubishi WD62528 projector tv is not powering on. when the tv is tuned on the timer light blinks for sometime before it becomes steady while the lamp light and status light is off. i sent a message...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem, and do take care in handling the set
May 27, 2011 | Televison & Video
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
Dec 03, 2010 | Hitachi 50C10 LCD TV
The color is really dim,
i have a wd62528 62" dlp hdtv that shows a picture but very dim. I have tried numerous things including factory reset and checking the lamp. I started to get a new lamp but was told if i have a dim picture getting a new lamp will do nothing. However, Mitsubishi support said that if i have a dim picture but was not continuing to get worse or darker, then they were 100% sure i just needed a new lamp. I'm confused. Will a new lamp solve my problem or no. i would just buy and try but it is very costly. please help
Nov 02, 2010 | Mitsubishi WD-62528 62 in. LCD Television
How do you replace the tail light bulbs on a 2006 Pontiac Vibe
Tail Lamp: Service and Repair
TAIL LAMP REPLACEMENT
REMOVAL PROCEDURE
1. Open the rear compartment lid.
2. Remove the rear compartment trim panel (4).
3. Disconnect the tail lamp electrical connectors.
4. Remove the following components from the vehicle:
- The 3 nuts (3)
- The tail lamp (7)
5. Remove the following from the tail lamp:
- The stop lamp socket (2)
- The turn signal lamp socket (5)
6. Remove the following from the lamp sockets, if necessary:
- The stop lamp bulb (1)
- The turn signal lamp bulb (6)
INSTALLATION PROCEDURE
1. Install the following to the lamp sockets, if removed:
2. Install the following to the tail lamp:
3. Install the tail lamp (7) to the vehicle. Secure the tail lamp (7) with the 3 nuts (3).
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the tail lamp nuts to 10 N.m (89 lb in).
4. Connect the tail lamp electrical connectors.
5. Install the rear compartment trim panel (4) to the vehicle.
6. Close the rear compartment lid.
Oct 30, 2009 | 2003 Pontiac Vibe
Lamp doesn't light on SP 500, SP-Lamp-017. How do
you'd need the lamp on to get into the menu to reset the timer, so it's not that. if the door hits and activates the switch, it may be the ballast.
Aug 09, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
NEED TO REPLACE A TAIL LIGHT BULB IN A 2005 CHEVROLET IMPALA
and Repair Notes TAIL LAMP REPLACEMENT REMOVAL PROCEDURE Open the rear compartment. Remove wingnut and pull back the rear compartment trim panel from the tail lamp. Remove the wingnuts from the tail lamp. Remove the tail lamp from the rear body panel. Disconnect the electrical connector from the tail lamp. Remove the tail lamp socket, turning counterclockwise. Remove the bulb from the tail lamp socket. Remove the sidemarker lamp socket, turning counterclockwise. Remove the bulb from the sidemarker lamp socket. INSTALLATION PROCEDURE Install the bulb to the tail lamp socket. Install the bulb to the sidemarker lamp socket. Install the sidemarker lamp socket, turning clockwise. Install the tail lamp socket, turning clockwise. Connect the electrical connector to the tail lamp. Install the tail lamp to the rear body panel. Install the wingnuts to the tail lamp. Pull back the rear compartment trim panel to the tail lamp and install the wingnut. Close the rear compartment.
Jun 08, 2009 | 2005 Chevrolet Impala
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
Mitsubishi WD-62528 62 in. LCD Television Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
