Question about GE Profile Harmony DPGT750EC Electric Dryer
GE Harmony dryer drum does not turn
Drum does not turn but the motor sounds like it is running , how do you get to the belt? or does it even have a belt one place I read says that it turns off of magnets.
  • alliecat65 Apr 06, 2009
    The blower is on- but it won't turn. It happens occasionally. When I had a service guy out- It ran when it had not been running earlier on.
  • 3 Answers
Open the top, pry up be careful not to chip your finish. It is hinged in the rear.
Is thr a wear spot around the drum?
It probably is belt drive
Posted on Feb 08, 2009
I have a 5 yr old GE Harmony Dryer and it sometimes does not turn the drum. I'd say about 2/3's of the time it operates totally normally, but the other times the drum doesn't turn and you have to open the...
Unfortunately your motor is bad.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are GE certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on doing it yourself, if you'd like.
The switch your talking about is a centrifugal switch inside the motor. Once the motor turns to a specific RPM, it makes and keeps the motor going until the timer turns it off or the door is opened. But it is the motor itself which starts the spinning. But the motor is not doing it's job so the C switch doesn't come into play.
Best, G
Aug 02, 2010 | GE Profile Harmony DPGT750EC Electric...
The dryer is getting power but the barrel isnt turning
If motor runs but no tumble, belt is broken. It broke due to overloading, old age, or bound up tension pulley or drum support wheels. You have to check all of these when replacing belt. Belt is fairly cheap.
Jul 02, 2010 | GE Profile Harmony DPGT750EC Electric...
Ge electric harmony dryer fan motor not turning just moves side to side 1/4 of an inch back and forth . fan freeweels free, if i spin it buy hand.
with belt off see if motor free spins .the blower wheel should not free spin with the belt on and entire drum will turn with it otherwise you could have a bad motor and a blower wheel
Jan 24, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Drum turns but makes a banging and metal grinding sound
The felt bearing on the front of the drum is worn out. Immediately stop running the dryer, and replace the plastic drum inserts and put in a new felt bearing before machine damage happens (if it hasn't already). While there, grease the rear bearing and the idler pulley bearing. Check the belt too. Good luck.
Nov 28, 2009 | GE Profile Harmony DPGT750EC Electric...
I turn the dryer on and the drum will not turn.
It sounds like the belt that turns the drum is loose or worn out and needs to be replaced. Another problem is that the motor is on the way out. Check the belt first.
Aug 02, 2009 | GE Profile Harmony DPGT750EC Electric...
How do you disassemble a GE harmony dryer
remove rear pannel and the motor is right there remove drum to acess the motor
remember to lay the dryer on an angle or even flat on it's face if you can to re insert the drum assembly and dont forget the belt
Jul 29, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony Elec. Dryer Blower Stops working or won't start up
Do this.
press "Home"
press "Help"
press both "My Cycles" and "Back" at the same time and hold them until service mode pops up.
It will tell you what's wrong.
Jul 22, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryers drum is not spining
I was having a similar problem but my dryer was about 5 years old. There are a couple of rubbery, sticky belts that wrap around the dryer drum. One of mine had come off the drum and was balled up, wedged between the drum and the dryer wall. It wanted to spin, but this "belt" was keeping it from doing so. I'm not sure why or how it happened, but I removed the portion that was gummed up and now it works fine.
Nov 25, 2008 | GE Profile Harmony DPGT750EC Electric...
GE DRYER STOP RUNNING
sounds as if the belt has snaped and the drum has droped stopping you moving the drum
Dec 05, 2007 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
130 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Are you a GE Dryer Expert? Answer questions, earn points and help others
