Question about Fender Passport Deluxe 500watt Sound System with Deluxe Speaker Array
Adding speakers to Fender Passpost 500 Amp system
We want to add extra speakers to this system. The original speakers are 8 OHM each.The additional speakers would also be 8 OHM and wired in parallel so the system would see a 4 OHM load. Is this OK? We could wire in series and make it a 16 OHM load (a bit more difficult, but possible.) Thanks in advance for your help.
    Problem Solver:
  • 17 Answers
If you add 8 ohm speakers in parallel then you would be running the amps into a 4 ohm load ...which will overheat and possibly damage them ...... if you wire series then the amps would be loaded to 16 ohms ...which would be ok ..but you will only develop 70 % of the total output power
IE a 100watt would be down to 70 watts
much better to add some seperate powered speakers
Posted on Feb 02, 2009
Fender super 210 guitar amp
8 Ohm. Here is a nice trick for you. If you use the ext speaker wire it the wrong way the + to black and the - to red. This puts the speaker out of phase with the others. Some like this effect. Have Fun
Aug 13, 2014 | Fender Music
How can I connect extra speakers to my BXL 1800 ultrabass
IF You don't have a separate external input jack. then you need to determine the overall impedance (ohm alottment ). so it will read something like 6, 8, or 16 ohm max. at that point look to see what your speaker output reads.(should be a plate on the speaker) if not, then disconnect speaker and put an ohm meter on it . it will give you a resistance reading , that is your ohms. so toadd a speaker, you must maintain not to exceed the rating. in hooking up. you can do it one of two ways. the first method woukld be , from the amp go positive to pos. side of speaker, and from the speaker neg. sid, go to the pos side of the speaker your adding . from the neg. side of that speaker go back to neg. side of amp. ( rthat is known as a series hook up. this doubles the ohm output of the two speakers ) - turns 4 ohms into 8, 8 into 16, etc. the other way is known as parallel. (from the amp take the pos.side and make a "y" and send those leads to each appropriate speaker. positive to positive. and do the same with the negatives. *this cuts your ohms in half. 4 int o 2, 8 into 4, etc. = hope that helps
Apr 05, 2014 | Music
I have a fender frontman 65r with a 8ohm speaker can i add another 8ohm speaker to this
http://cie-wc.edu/Series_Parallel_9_14.pdf
Not recommended.
you could add 3 more 8 ohm speakers in series / parallel wiring and keep an 8 ohm load to the amp, or
2x 4 ohm speakers in series, or
2x 16 ohm speakers in parallel
Jan 11, 2014 | Fender Frontman 65R 65W 1x12 Guitar Combo...
One of my Fender Passport 500 speakers has started to crackle sometimes, particularly when the song has a lot of base. What could be causing this? Would a regulator help?
You have probably blown the speaker... swap left and right to verify it is the speaker... These speakers are NOT too well suited for bass... They typically have low impedance speakers in series. You run a risk of popping the amp running with a blown speaker. You MAY have to replace all the speakers in the defective cabinet. ALL the speakers must be identical. The Passport 250 uses four 2 ohm speakers in series... not sure about the 500. It may have two 8 ohm in parallel. Do not use the speaker until it is fixed... the amps are hard to repair if a defective speaker cooks them.
Sep 08, 2011 | Fender Passport Deluxe 500watt Sound...
How do you switch the behringer 3000 to bridged mode,what settings do you use to get 1200 watts out of it.
Well... you probably won't like this, but here is some info: In bridged mode, a different Speakon to speaker cable is required from only the B... it is wired differently and you can only use one of the plugs. The speaker or speaker system CANNOT be less than 8 ohms in bridged mode... this precludes using speakers in parallel or multiple speakers that are less than 16 ohm impedance... such speakers are NOT commonly available as most are either 4 or 8 ohm. There is a slide switch for bridged mode on the face of the mixer. Next thing you won't like... The 1200 Watts specification is PEAK power, NOT RMS... You can get 400 watts RMS per side USING 4 ohm speakers. If you use 8 ohm speakers, each of those will get 200 watts. I use this mixer myself and ALSO repair them. The voltage swing at the outputs is about +/-60 volts MAX (peak). This is about 40 volts RMS by the time the circuit LOSSES are taken into account. Across a 4 ohm speaker you get 10 amps times the 40 volts or 400 watts. Across an 8 ohm you get 5 amps or 200 watts. The voltage rails in the switching amp are +/-70 volts DC so these are reasonable values. Bridged mode just uses both sides of the amp driven in opposite directions for higher voltage out BUT you have to use no less than a single 8 ohm speaker so there is NO advantage to bridged mode power wise. IF YOU NEED more power, use extra speakers from an additonal amp driven by the 1/4 TRS mains output jacks OR use additonal POWERED speakers driven from the same jacks. Please read my tip about the hazard regarding the SLEEVE of the cahnnel A cable when using Speakon to 1/4 plug cables being the HOT and the tip being the cold for channel A. Ground the sleeve accidentally and goodbye channel A amp...
May 10, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I Have a Peavey XR 600B mixer. There are only 2 inputs in the rear for speakers. I want to add more speakers to be used as monitors or just have extra speakers. How can this be done? I only have...
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
Mar 06, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
What is the best suited power amp for the Peavey PV14 mixer board?
that depends on your speakers, not the mixer. the amp should be matched to the speakers, in watts and in ohmage. for example, 400 watt, 8 ohm speakers should get an amp that runs at 350-500 watts at 8 ohms.
Apr 22, 2010 | Peavey Pv 2600 Power Amplifier
What's the best way to connect a PC (with DJ software) to a Fender PAssport 500 PRO (I want stereo input)?
Best way is to use a 1/8 TRS (stereo) to 1/4 TRS (stereo) cable from the PC into the Stereo 1/4 inch jacks right below the RCA stereo input jacks.
TRS stands for tip-ring-sleeve which means the jacks have the extra "ring" over a mono jack.
Jan 28, 2010 | Fender Passport Deluxe 500watt Sound...
Not really a problem want to know if I could add a extention speaker to the fender rumble 100 combo it has not ext. speaker out looking to add two 10 inch and if so how?
Hi there. If 10" speakers are 8 or 16 ohm, parallel them. If they are 4 ohm, series them. if "External speaker" output is rated down to 4 ohm. If no external speaker jack, you'll have to tap into existing speaker jack with a "Y". Check the minimum ohm load for the amp.
Thanks
Paul
Jun 03, 2009 | Nomad Factory Fender Rumble 100 Bass Combo...
I want to add more speaker at my paspor fender 500
Run out of the stereo output jacks into a separate amplifier and speakers. The amplifier send jack only sends signal from the particular channel it is part of. In other words to get all the signals from all the channels you would need another mixer, amp and speakers. It is easier to use the stereo out which will give you all the signals. If you only use left out or right out make note of where your panpot is set for each channel.
Mar 03, 2009 | Fender Passport Deluxe 500watt Sound...
Fender Passport Deluxe 500watt Sound System with Deluxe Speaker Array Logo
193 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
