Question about Toshiba TN43V71 43" Rear Projection Television
Will not power on but red blinker is on.
My tv just turn off on its own the other day and now when i try to turn the tv back on, i get no picture or sound. however the red blinker does come on. could this be a power supply problem? i have a few friends who have purchase the tv around the same time i did(1999) and they are experiencing the same problem.
  • William Vong Jul 26, 2007
    could you give me a rough estimate of how much it would cost to repair a problem like this? would you recommend this as a DIY or should professional technicians take matters?
  • connoley Oct 04, 2008
    We have the Toshiba model MD20P1 and it shut off in the middle of a show we were watching and when we try to turn it back on the little red little comes on and the picture shows up for a split second, but it will not stay on.
  • 87 Answers
Your set likely has a bad convergence ouput ic that has caused a fuse to blow. The convergence output ic type number is STK392-110. These can be replaced with STK392-120 or STK394-160. It is good practice to replace both ic's because the one that is not defectie now will likely fail soon. The fuse may be a small glass fuse or a pico fuse. One is for about +28V and the other is for about -28V. Also to the left of the heat sinks for the convergence output ic'S you will find (2)small wires that have black insulation on them. It is very possible that one or the other of these have bad solder connnections.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Jul 24, 2007
SOURCE:
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV repair
Good Day;
Try resetting the TV by unplugging it from the wall. Plug back in after 5 minutes. If, no fix; call for An Authorized Service Center and have come out and give you an written estimate B4 repairs, most repairs on PJTV's avg $525.00. Good Luck, big IRISH.
Aug 25, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Jul 31, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
the flashing light often shows malfunction ,check the wire connection of your devices something must be wrong .the surge protector you have is for overpower or low voltage too?Ask your neigbours if they have shame problems
Nov 18, 2007 | Hitachi 46F510 46" Projection HDTV
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Toshiba TN43V71 43" Rear Projection Television Logo
226 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
