Question about Cybex Remanufactured 700c Upright Bike
Is there an electrical adapter for my cybex 700 upright bike
Trying to connect my new Cybex 77c upright bike to internet do I just plug the Ethernet cable to my modem
sure thing.
the modem should give the bike a number
like this one 192.168.0.110 'example'
Jan 03, 2018 | Internet Computers & Internet
Feels like pedals slip once in a while. How do I repair this please?
replace the spring, maybe it has lost some of the loading and become "tired".
Jul 03, 2015 | Cybex Cyclone 530c Upright Exercise Bike...
Cybex 600c trotter bike will not stay in manual mode then display turns off
Does anyone have a Cybex 600C Fitness cycle owner's manual and parts catalog?
Dec 03, 2013 | Cybex Exercise & Fitness
Need manual for cr350 recumbent bike
dont think thers one...ive search the web,called cybex and evrything and nothing...but if you so happend to obtain one please let me know.
Sep 11, 2013 | Cybex Used CR350 Recumbent Bike
I bought a used Cybex Trotter 700 T treadmill that works fine except the increase speed (+) does not work. I tried to fix it and now all of the buttons don't work. Any sugestions?
Dear Sir:
This is probably a 1(faulty speed sensor or the 2( speed sensor is not plugged in properly. Its also possibly a 3(faulty motor control board or lower board+ 4( Main motor faulty. Adjust the speed sensor see the diagram.
Run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for HELP
sincerley. God bless you.
ernesto cuadra
managua, nicaragua.
Mar 10, 2012 | Exercise & Fitness
I have a Cybex 700C upright exercise bike--it is an alternator powered unit. The display is dead. I have the bike apart, and everything looks fine inside, so I wonder if the most likely suspect is the 6V...
I would start by checking the voltage of the battery, before just replacing it. I will attach a link to a video on how to do this and also a link to the possible battery if this turns out to be the issue.
Video about How to Test Battery
Parts for Cybex Equipment Treadmill Belts Grips Pedals SPORTSMITH net
Oct 30, 2010 | Cycling
Cybex 700R will not power up.
I have a Cybex 500 and am looking for a user manual. Mine also stopped working. It's due to the internal battery running down. What you need is to plug a Power supply into the bike. I used one of these multi voltage adaptors. At the front of the bike you will see a point to plug the adaptor that fits snuggly into it. Mine was set to 12v with a positive pole to center contact. There is a diagram on the front of the bike to show you although mine wasnt marked pos or neg.
Switch mains power on and you'll get a series of displays scrolling. You'll be able to now use the bike. I left mine plugged in for 24 hours which charged the internal battery and now works perfectly again.
If you can now help me with the manual for the 500 Only want the setup pages. (1 or 2).
Thanks.
Sep 02, 2009 | Exercise & Fitness
Cybex Recumbent bike has been pre-set to not exceed 30 minutes
This is from the owner's manual from a slightly different Cybex bike, but will probably be the same for yours. From the dormant mode (waiting for a user), enter Clear-7-5-0-Enter
Pause/End will reset to factory default (hold down for three seconds)
Level keys scroll forward or back in menu
Menu item 7 is "Max Time," set it to OFF
Apr 06, 2009 | Cycling
Cybex Remanufactured 700c Upright Bike Logo
29 people viewed this question
Top Cybex Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ray gallant
Techmotionusa.com
Techmotionusa.com
Are you a Cybex Exercise and Fitnes Expert? Answer questions, earn points and help others
