Question about Olympus WS-100 Digital Voice Recorder
Only recording 59 minutes in LP mode
I have successfully used this recorder for recording 4 hours or so, but now am reduced to only 59:17 for recording time in LP mode. I am using the mic on High, and have no other specific modes changed- also, the recording is sounding very tinny or echoey, unlike before. anyone?
My WS-recorder did something simular to me. I hadnt used it for a while then it would only hold about 20 min. of recording no matter what record mode I selected.....so..... I held down the menu/folder button to get to the menu "mode". Press the FF to scroll through until you get to "FORMAT". Press Play and the screen will show "NO"...press FF to chose "Yes" it will ask you "are you sure" press FF to say "YES" then play to make it reformat. It hangs out for a couple of seconds then after that I have my regular 4 hours of record time back. ***** I would make sure I had downloaded all my info off the WS-100 BEFORE I did a re-Format.**** I dont know why it worked, but it did. I like this little recorder and Im glad to have it functioning properly again. The tinny/echoey sound could just be the environment you are in. Even how close or far it is from the subject...how many people are in the room....if a fan is on in the room....This little thing isnt super high quality in its play back mode....hook it up to you computer speakers and you will like the sound much better. Good Luck.
Posted on Sep 02, 2007
Works like a charm! thanks!
Posted on Feb 01, 2008
SOURCE:
Why does my camera stop recording after one hour? i need to record 90 minutes
Your camera records in two modes: SP and LP modes. SP is a higher quality mode that runs for about 60 minutes, while LP records for 90.
To change to LP mode, open the menu and select [VCR setup]. Select [REC MODE], set it to [LP] and close the menu.
Keep in mind that your video and audio will be of noticeably lower quality with this setting applied.
Mar 08, 2011 | Canon ZR200 Mini DV Digital Camcorder
Olympus Voice Recorder says only 6 hours time when it's empty
Hello
The recorder should be formatted only by using the internal FORMAT function found in the Menu. Formatting using the computer may corrupt system files needed to run the recorder and may delete the Voice Guide Data and Audible system files, so computer formatting is not recommended. When the recorder is connected to a computer, individual files can be deleted using My Computer without negative effects.after you format the unit this is how needs t
be depends on your selection for Audio quality
STEREO XQ mode: 17 hours 30 minutes
STEREO HQ mode: 35 hours 10 minutes
HQ mode: 70 hours 20 minutes
SP mode: 138 hours 30 minutes
LP mode: 275 hours 20 minutes
if this don't solved your problem you can get one really cheap athttp://www.tvps.com/Products/Olympus-DS-50-1-GB-Digital-Portable-Voice-Recorder---Demo-DS50__OL-D-DS-50.aspx just like a back up
Feb 10, 2010 | Olympus DS-50 Digital Voice Recorder
What are the differences in the record modes? (HQ, SP, & LP)
The amount of recording time on a disc depends on the recording mode selected. The approximate recording time for each of these modes is listed below:
  • HQ (High Quality): Recordable time is up to 20 minutes.
  • SP (Standard Play): Recordable time is up to 30 minutes.
  • LP (Long Play): Recordable time is up to 60 minutes.
  • NOTE: If you record in LP mode, the quality of the scenes may be degraded, or scenes with quick movement may appear with a block noise when you play back the disc.
    Jul 08, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
    EVERYTHING YOU NEED IS IN MY LETTER BELOW.
    1. On your remote, find the record mode button; it is near the bottom on the left side. This button sets
    the recording speed for the DVR. Faster recording speeds provide higher quality recordings.
    2. Look at the display on the front of the machine: it should say XP ( records 1 hour on the disc,)
    SP ( 2 hours, ) LP ( 4 hours, ) or EP ( 6 hours. ) You can also set it to record 8 hours on a disc,
    but the quality of the recording will be poor.
    3 Press the record mode button until the screen displays the recording speed that you want.
    4 Note: if the powers fails or the Machine is unplugged, the machine will automatically reset itself to
    SP mode.
    Apr 29, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
    Limited recording time
    WS-100: 64 MB
    HQ mode: Approx. 4 hours 20 minutes
    SP mode: Approx. 8 hours 40 minutes
    LP mode: Approx. 27 hours 20 minutes
    You can go to the menu of the device and change the recording mode from HQ to SP to get longer recording time. Page 7 of the instructions explains how to change this.
    Mar 19, 2009 | Olympus WS-100 Digital Voice Recorder
    Magnavox DVD recorder...finalizing problem
    The manual isn't too helpful either - "Recording error other than below," it says. There are a couple of possibilities. The Philips/Magnavox/Funai recorders automatically record in VR mode when you use +R discs (there are two possible recording modes - V Mode and VR Mode). Is it possible that you have switched disc types lately? If you are currently using -R discs, switch to +R and vice versa. The manual states that +/-RW discs take a while to initialize.
    I couldn't find a full factory reset on that one, so you may have to unplug the unit for about 20 minutes to restore all the defaults.
    Another possibility: Finalization requires some extra space on the disc. If you accidentally pressed the button that changes the recording format between SP, EP, LP, etc., you may not be able to fit the same amount of video on the disc that you were able to fit before. You can change the format by pressing the Disc Mode button on the remote - LP Mode will fit 3 hours worth of recordings onto a 2-hr disc and is considered a "medium quality" recording. Try changing the Disc Mode to LP and see if it will finalize the next disc that you record. The downside of this possibility is that the discs that you have already made that are giving you errors are not "fixable" - you will will have to re-record the shows to a new disc in LP mode.
    -Tha Mp3 Doctor
    Feb 11, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
    Recording from VHS to DVD
    First, you will need to know if the program was recorded in XP mode, SP mode, LP mode, or EP mode. To find out how much room there is left, put the dvd in the tray and press the Disc Menu/List button on the JVC remote. This will display the title and how long it is - write that number down. It will also say either "XP,SP, LP, or EP" - write down that mode. In XP mode, a DVD will hold 1 hr and 20 mins worth of prgramming - MAXIMUM. SP mode = 2 hours. LP mode = 4 hours. EP = 6 hours. So, if your program is one hour, and you recorded in LP mode, you have 4 - 1 = 3 hours of space left for recording on that disc.
    If you finalize a disc, you will no longer be able to add more programs to that disc, unless the disc is a + or - RW disc. Also note that finalization requires some disc space, so if you recorded a program that is exactly 1hr and 20 mins long, and you recorded it in XP mode, then the disc will probably not finalize correctly.
    That being said, the finalization directions are on p. 23 of your manaul: Title --> Finalize --> => --> find finalize --> Enter --> OK --> Enter
    Now it will play on other players.
    Here is a link to the user manual:
    http://resources.jvc.com/Resources/00/00/93/LPT1133-001A.pdf
    -Tha Mp3 Doctor
    Dec 31, 2008 | JVC DR-MV7 DVD Recorder/VCR
    I am recording fron VHS to DVD. When I am finished and push the stop button, How can I tell how much space is on the DVD to record something else and how do I finish the dik so it can't be recordered over
    JVC DVD Recorder – Finalizing and disc space
    -Tha Mp3 Doctor
    Dubbing from VCR to DVD
    Dont use xp mode. Here are the definitions:
    SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
    LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
    EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
    Sep 02, 2017 | LG LH-C6235 System
    DVD copying
    There are double layer DVD's that they make which usually have about 2x the memory. check to see if your DVD recorder supports these types of DVD's. You could also just divide your media on to two sides of a double sided DVD (each side has the mirror look and you can record onto both sides)(still the same disc) or you could record on to multiple DVD's (may be inconvenient but is still an option). Also, you could reduce the recording quality just a bit so that it is not noticable when you watch it but it still uses less space on the disk. I would tell you how to do these things but I have no experience with the individual model that you have.
    Mar 22, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
    Olympus WS-100 Digital Voice Recorder Logo
    70 people viewed this question
    Top Olympus Audio Players & Recorders Experts
    Ekse
    leoz
    Level 1 Expert
    Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
