Question about RTO Comfort Zone Electric Portable Space Infrared 1500-watt Heater
How to change celicus to farenheit on a duraflame heater
My flame quit working in my red core heater.
Amazon.com - Redcore S2 IR Stove Heater - Space Heaters
www.amazon.com/Redcore-S2...Heater/.../B008QJV9...
Amazon.com, Inc.
Rating: 3.7 - ‎29 reviews
Buy Used and Save: Buy a Used "Redcore S2 IR Stove Heater" and save 68% off ... The flame is very realistic - my son and his friend thought this heater was a real wood stove. .... Also, the door was broken off the hinges when we received it.
FAQs About PowerHeat - DURAFLAME ' TWINSTAR ...
www.twinstarhome.com/duraflame/pages/faqs/index.html
What is quartz infra-red heat? ... It seems that the thermostat on my PowerHeat is different from what I believe the actual room temperature to be. ... When the heater isnot running, PowerHeat periodically runs a temperature accuracy test.
Customer Reviews: RedCore Concept S-2 Infrared Stove ...
https://www.walmart.com/reviews/product/22070668
Walmart
Jan 10, 2016 | Heating & Cooling
How to get it from celsius to fahrenhite
X=degrees celcius
Y=degrees farenheit
(X)1.8+32=y
Dec 10, 2015 | Duraflame Colby Indoor Infrared Quartz...
I have a 240 v duraflame celling heater .and it won't turn off even at the lowest setting.
the contact's in the thermostat have fused together. You need to replace the thermostat before using the heater.
Feb 15, 2015 | Heating & Cooling
I have a duraflame electric heater that starts to smoke and nake poping noises when i plug it in is it malfunctioning or is it repairable
wow, unplug and look for a new one. The cracking and popping is usually signs of something cooking the wrong way inside. You might lok to see if something is inside that ought not be inside. A good inspection while it\'s unplugged is also good in checking what is actually broke. 9/10 times it\'s wiser and more cost efficient to just buy a new one. cut the cord off the old cord and properly dispose of it.
Dec 31, 2014 | Duraflame Fan Forced Utility Heater...
What does it mean when my heater says er
It means there is something wrong with the heater or the controller fro the heater.
Oct 05, 2014 | Duraflame 1500 Watt Heater-Fan with...
Duraflame heater runs for 5 mins and shuts off
try cleaning off the filter that is on the bottom in the back of the unit. It is a fail safe sensor that in the event the unot overheats it shuts off the heater. Worked for me on mine.
Oct 06, 2012 | Duraflame Colby Indoor Infrared Quartz...
RTO Comfort Zone Electric Portable Space Infrared 1500-watt Heater Logo
588 people viewed this question
Top RTO Pool & Spa Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
