I need a replacement on-off switch for a MUSKOKA MES32BL-2 heater. Any ideas where I can find one.
Muskoka mfb28-2
There is a capacitor that is bad. The capacitor regulates the phase of an AC motor. It looks like a can shaped object.
Dec 12, 2013 | Garden
Where did Adirondack Chairs get their name?
Adirondack Chairs are also known as the Muskoka chair. Adirondack is the name of the mountains West Port NY where the inventor Thomas Lee needed chairs for his summer home. Muskoka as in Muskoka Ontario.
Jan 17, 2013 | Garden
Muskoka electric fireplace ,the switch doesnt work
  • Unplug the fireplace
  • Open up the fireplace to gain access to the inside.
  • Inspect switch for charring, melting, etc.
  • Inspect circuit board for charring etc.
  • If indeed the switch is the culprit: then...
  • Unhook the wires from the switch.
  • Remove the switch.
  • Bring the switch into your local hardware store or radio shack.
  • Buy a compatible switch - pay attention to amperage markings etc. so your new switch can handle the power.
  • Install new switch and re-hook up the wiring.
  • Close up the fireplace and enjoy...
Nov 25, 2012 | Heating & Cooling
Why are Adirondack chairs also referred to as Muskoka chairs?
These chairs were given the name Muskoka chairs due to the popularity of them used in the area of Muskoka, Ontario (a cottage country area north of Toronto, Canada).
Aug 26, 2012 | Adams Garden
Adirondack Chairs are also known as the Muskoka chair. Adirondack is the name ofthe mountains West Port NY where the inventor ThomasLee needed chairs for his summer home. Muskoka as in Muskoka Ontario.
May 29, 2012 | Garden
I would like to know how to repair the on/off switch on a Muskoka electric stove model MES30BL-1. Thank you.
I have a Muskoka MES30BL-3 Phoneix electric stove. I turn on, it stays on a little bit and then goes off. What's wrong?
Mar 22, 2011 | Kitchen Appliances - Others
Hello, I have a 2006 2500HD 6.6 vin 2. The drivers side seat heater has been coming on and going off by itself. Ideas?
I have had the same problem with my Silverado truck, driver's side seat heater. Previous 3 chev dealer repair efforts focused on the Drivers Door Module, replacing, then reprogramming it, and also replacing the seat heater switch (in door). However, I found a Tech Service Bulletin on alldatadiy which says you need to reprogram the Driver Seat Module (not Door Module), and I am taking it back to dealer tomorrow. Will report on results.
Oct 27, 2010 | Chevrolet Silverado 2500HD Cars & Trucks
Jandy Lite 2 LP 400 will not activate the ignitor. Power is on.
Somewhere on the panel or inside there shpuld be instructions telling what 4 flashs represent...
Could be a high limit that needs reset, a rollout switch the needs reset, or a pressure switch if you have a vent blower on that unit...
heatman101
Apr 24, 2010 | Jandy Lite2 LJ125 Ceramic Gas Heater
Audi 80 tdi 1993 ,Lights horn and heater stoped working....not fuses any ideas???
Go to an auto-electrician and he will replace or will fix all these problems. I think they are very simple to be repaired (but not the heater). i have all these problems and i haven't fixed them yet . the heater does't cost much but it cost's it's implementation in the car (it's a 1 or 2 day's work) because the electrician must remve the entire hood and the console). The lights and the horn are in the steering wheel place (the lights maybe are blown and need to be replaced or it's the switch that doesn't work properly like mine because my light switches need to be replaced!)
Jan 07, 2010 | 1992 Audi 80
Laars Lite heater not working
1st time this happened to me the filter wasn't clean. 2nd time it was the pressure switch and for the third time they say I have to bleed the gas line, not enough gas to lite. And I also need the on/off switch gone bad.
Jun 08, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
234 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
