Question about Delsey Helium Shadow - 25 Trolley Luggage : One Size
Directions for setting and opening delsey tsa002 lock
Combination lock won't open - changed one of the numbers to set the lock, then reset it to combination and the lock will not open, no key with me
2 Suggested Answers
Micoman
  • 198 Answers
SOURCE: how to reset built in lock on my Delsey Helium suitcase
The default combination of new lock is always 000..If you forgot the correct combination, it is not possible to reset it.
Posted on Jan 07, 2016
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
How to reset built in lock on my Delsey Helium suitcase
Jan 07, 2016 | Delsey Helium Shadow - 25 Trolley Luggage...
TSA opened our lock on our Delsey luggage, I now am unable to lock the suitcase. How can you reset the lock on the Delsey luggage after unlocked by TSA?
1. Look for a small recessed button below (on the bottom side) the TSA key access.
2. Push in the button with a paper clip or pen.
3. While the button is pushed, change the combination to the desired numbers.
4. Then release the button and the combination has been reset.
I also found this, but it needs to be open/
http://www.ehow.com/how_6927475_reset-tsa-lock.html
Dec 08, 2015 | Delsey Helium Shadow - 25 Trolley Luggage...
Tsa002 change combination
Most combination luggage locks can be reset when they are open. The combination wheels can't be turned unless the lock is being reset. So either the wheels show the correct combination, or you will be able to turn them to a new combination. The lock that is "locked outside the hole" was either not relocked after inspection or it's in reset mode.
Jul 04, 2014 | Locks & Locksmithing
I previously set my combination and it worked fine. Now my combination will not work on my cal pak lock luggage. how can I open now and reset combination?
Try rotating the numbers on the combination dial three times to clear any previous entry (stop on the zero's if this applies) and enter your combination one more time to see if this works and gets it open.
The default is 000; to set it, hold the lock open, move the dials to your numbers, and close/open three times. This will set the combination to your numbers.
Aug 27, 2011 | Locks & Locksmithing
Get the numbers master dial combination lock
Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
Please rate. Thanks
Feb 21, 2009 | Hardware & Accessories
I want to change my Master Lock combination
open the shackle twist 180 degrees...shut it as if u were closing it into the locking device..hold it down, put in what ur new combination is..pull the shackle up and shut it into locking device, and test it out.
Jan 25, 2009 | Master Lock 5400d: Portable Select Access...
Forgot my 3 digit number lock on my samsonite bag
lost 3 digit no on samsonite TSA002 lock
Sep 17, 2008 | Samsonite Tripod
Delsey Helium Shadow - 25 Trolley Luggage : One Size Logo
436 people viewed this question
Top Delsey Luggage & Travel Experts
Andrew Taylor
Andrew Taylor
Dave braun
Dave braun
Bobby Lewis
Bobby Lewis
Are you a Delsey Luggage and Travel Expert? Answer questions, earn points and help others
