Question about Dell PowerConnect 2016 (pct2016) Networking Switch
Network my desktop with my laptop
I would like to set up my desktop and my laptop to network together.
I have a Dell power connect 2016 that I used once years ago (way before huge external hard drives) to transfer all the data from one pc to a nother years ago during an upgrade. I now use a laptop on the road and would like to create a home network to sink the two copmuters when home. I thought it would be just plug and play so to speak, hovever it seems there is more to it than just plugging the 2 computors into the power conect and hitting enter.
Any help will be appreicate,
mpiguy
    Scholar:
  • 60 Answers
Internet -> Port 1 or 16 ComputerA -> Port 2 ComputerB -> Port 3
I say port 1 or 16 because on older equipment there is an uplink port that is usually either the lowest or highest port number depending on the manufacturer. Set both computers IP addresses to use DHCP in this scenario. If you aren't connecting to the internet, both computers need to have their ip address set manually to a number in the same "neighborhood" (i.e. set A to 192.168.1.2 and set B to 192.168.1.3), then they will see each other.
Posted on Jan 28, 2009
  • Allan Claunch
    Allan Claunch Jan 28, 2009
    P.S. If this switch is super old you may have to use a special ethernet cable called a "crossover" cable which has the wiring flipped on each end, later models introduced a button which could do the same thing with a regular cable, this button is a good indicator of whether it is port 1 or 16 because it will be located next to that port. Today's models now autosense whether the uplink needs to be crossed over or not so you no longer see this button on modern models.
Network cable connection not recognized
Make sure the LAN driver is installed and working.
The LAN cable maybe faulty, try another one.
If the LAN cable is a red one then it most likely a crossover LAN cable. This cable is used to connect two computers together without a LAN hub or router.
Sep 21, 2012 | Dell XPS M1330 Laptop Computer PC...
For my Dell Dimension 2400, I'm trying to use the Network Setup Wizard, but I can't because it says there is no hardware... Do I need a certain driver or program? I have an ethernet cable that is connected...
To connect your computer to the Linksys wireless router using the LAN card in your computer you need to install the LAN card driver. If you want to use a wireless connection with your Dell desktop, you will need to install a wireless card on your Dell plus the wireless card driver.
For the LAN card driver, download the driver from the Dell WEB site.
You can download the device drivers from Dell WEB site,the support download page. Make sure you select your model desktop or laptop,better still, type in the Service Tag number, it is printed on the label on thebottom of the laptop and on the back or sides of a desktop. (If the Service Taglabel is missing then go into the BIOS setting and on one of the BIOS pages,the Service Tag number will be displayed). This will open the page where thespecific drivers for your model computer are located. Also make sure you selectthe Windows of the drivers for your Windows operating system. Click on thislink to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
May 02, 2011 | Dell Dimension 2400 PC Desktop
Dell powerconnect 2016 seems to have stopped working
most likly a failed power supply on the switch
look at the front of the switch look for leds,.......
if you see nothing and the power cable is plugged into a hot outlet than
go down to your neerest comp store and buy a new one
Apr 26, 2010 | Dell PowerConnect 2016 (pct2016)...
Dell 1450 wireless adapter won't connect to home desktop; it doesn't even see the network. It will connect to 2 laptops and an iphone Any idea why it won't see our home wireless network and all other...
my be you home network desktop has an different network range or
your desktop has configured with an ip address manually configured or
your proxy is restricting the internet to disable proxy settings in IE go to tools --> internet options --> connections --> lan settings --> and uncheck proxy
For firefox tools --> options --> advanced --> network --> settings --> noproxy
Apr 06, 2010 | Dell 1450 (D1450U) Wireless Adapter
Can't connect through my wireless G network adapter.
Give the default gateway address of your laptop computer in the desktop computer. this will solve your issue.
Sep 02, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Setting up and configuring networks
The main problem on your setup is your router. This BEFSR41 doesn't have wi-fi or wireless capability. You can only go online on your laptop if you connect it hardwired to the router just like your desktop. You must purchase a wireless router if you want your laptop to work wirelessly
May 09, 2009 | Linksys BEFSR41 Cable/DSL Router with 4...
Cant connect router & dsl modem, cant aquire ip address
Try typing another website on the address bar.
Try checking on your router advaced setting make sure that Mac filtering is off under network filter.
Make sure all other settting on the advaced setting are also in default setting.
Jan 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Can i use a usb adaptor on the c700
Your laptop should have a built in network card and 10baseT network port, if your laptop does not have a built in network card you can use either a PCMCIA network card or a USB network adapter. Your desktop computer may not have a network card, you will need to purchase a network card and install the drivers.
To connect the two computers together you only need a cross over cable. If you use a hub you can connect two or more computers together using standard 10baseT network cables.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Dell PowerConnect 2016 (pct2016) Networking Switch Logo
293 people viewed this question
Alun Cox
