Question about LG Vu CU920 Cellular Phone
LOADING MUSIC ONTO LG VU
WHEN I LOAD MUSIC ONTO LG VU, WHETHER BY USB CABLE OR MICRO SD, IT SHOWS UP UNDER THE RINGTONES SECTION, NOT THE MUSIC PLAYER SECTION. HOW DO I GET MY MUSIC INTO THE MUSIC PLAYER SECTION???
  • 9 more comments
  • Anonymous Jan 28, 2009
    I have the same problem
  • ahmedali4u Jan 30, 2009
    I have the same problem. When I load music on the memory card, it appears in the audio and ringtones section, and not on the AT&T music player.
  • wesleyholmer Feb 08, 2009
    I've tried everything i can think of and the music still ends up in the ringtones section! what should i do?
  • hd dan Feb 25, 2009
    wheter I use the USB cable or a card reader to transfer the music, it does not show up in the music player. If I play it from the card, it will only play 1 song at a time.
  • chrisdog1 Mar 03, 2009
    when i put songs onto my phone i try to put them on there using the music sync ON WINDOWS MEDIA PLAYER but it will load up to about 99 percent and then my phone will cut off and the songs wont show up on my music player. but the only way i can put the songs on my lg vu is if i go to connection usb settings on my phone and put it on mass storage and the songs come on my phone but dont go under my music player its in the same spot as my ringtones wich i dont like
  • noelrohr Mar 08, 2009
    ditto, does no one know how to fix this? i am very tech savvy and this boggles my mind. Ive come to the conclusion that it is the cu920 not me that has the defect.
  • KRiiSTiiE25 Mar 09, 2009
    ITS SO ANNOYING. BEFORE I GOT A NEW MEMORU CARD IT WAS PLAYING MY SONGS IN THE MUSIC PLAYER. NOW IT WONT. MY MEMORY CARD WONT EVEN FORMAT. AND WHEN I PLUG IT IN WITH THE USB CORD IT DOESNT FIND IT
  • Anonymous Mar 19, 2009
    i cant figure out how to even get the music on my phone its mad annoying
  • og_301 Mar 26, 2009
    well my songs were showing on the ringtone section and the music player but now my music player just says i have no songs but the ringtones section still does! i don't know why
  • drmaheshlj Mar 29, 2009
    When I load songs with USB it goes to ringtones section not in the player
  • Anonymous Mar 30, 2009
    when i download music it shows up in my audio and ringtones.! and not in the music player.. i asked everyone for help.. the solution i got, was get a sandisk memory card..! it's the only kind to work in this phone!!! it's stupid!! but whatever!!!
In preferences, more options, there's a connection section. try setting it to music sync
Posted on Jul 07, 2009
I cannot download pictures from my LG Neon gt365 to my computer. What do I need to do? Do I need a USB? Do I need a micro SD? If so, what kind do I need? any help would be great!
You should be able to connect it using a usb cable that will need to be bought separately and a micro SD card installed in the phone. You should be able to buy any micro SD card up to 4GB. Also, if you buy a card with an SD adapter that will allow you to connect the SD card (with a memory card reader) to your computer without the additional usb cable. The manual link is attached: http://www.tmoatt.com/uploads/53/LG_Neon_GT365_UG_English.pdf
Per the manual:
Transferring Music from the Digital Music Service 1. Using your computer, open your preferred PC music management client. 2. Download the selected song to your library. 3. Make sure the microSD™ card is inserted properly into the handset. 4. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 5. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device. If the detection does not occur, skip to Changing USB Connection Settings section on page 63. 6. Follow the instruction in the program to transfer music to your handset. n Note If you have a USB hub, connect the handset directly to your computer rather than through the hub. Transferring Music using Windows Media Player 1. Open Windows Media® Player on your computer (version 10.0 or higher). 2. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 3. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device.
Jul 23, 2011 | Cell Phones
I cant get my LG VX9200 to accept my WMP files
How are you loading them?
I have successfully used the Micro-SD card by removing it from the phone (Power the phone off first, please!), and inserting the micro-SD card into my PC card reader using an SD-Card adapater, which makes it appear as a Drive to my (WIndows) PC.
I then just copy music files into the "My Music" folder, and they show up when I put the card back into my phone.
I have also been successful using a USB cable, and then settting the phone to "Main Menu | Settings & Tools | Tools | USB Mass Storage" Then the phone looks like a disk on my computer, and again, I copy the files into the "My Music" folder on the micro-SD card while it's in the phone. Don't know if you can copy to internal phone memory in this method; I've never needed to try it.
A couple of things: I'm using ".m4a" files out of iTunes; I have also used ".mp3" files I've edited as ringtones, but I haven't tried ".wmp" files, so I don't know if it's a file format issue.
So are you successfully copying files to your phone and just not able to play them, or are you not able to even get them copied onto the phone?
Jan 28, 2010 | LG enV3 VX9200 Cell Phone
Music player will not recognize songs. They only go into Audio/Ringtones?
make sure you are storing your music on a micro sd memory card of up to 4 GB.
Jul 29, 2009 | LG Vu CU920 Cellular Phone
Music Player
you should try building a play list i think it will scan that card to build the play list for the muisc player..... hopr it works let me know
Feb 16, 2009 | LG Vu CU920 Cellular Phone
I want to put music on my new phone. the LG VU but dont know how
YES you CAN put music on your phone without USB cable!!! just drag and drop music from your computer to your SD card/adapter(usually F: drive) , click SD card into LG Vu (make sure "connection", in "settings" is set to "mass storage" on phone!
Dec 30, 2008 | LG Vu CU920 Cellular Phone
Idk how to put music on my phone
Make sure your music is mp3,wma,aac,aac+,or eaac+ format.Insert the micro sd card into the slot underneath the sim card in the back of the phone.Turn on the phone and connect it to ur pc using a usb data cable once the portable device pops up on ur screen use the second option.From within windows media player songs will populate the left side of the screen.check drag songs to be transferred then click start sync when finished tap cancel on the phone then yes to exit music and disconnect the usb cable.
Dec 23, 2008 | LG Vu CU920 Cellular Phone
Importing music...
Now a days you are getting latest Mp3 players with Micro SD card fecility. Buy them and copy the mp3 songs from computer to Micro SD and shift that from mp3 player to your lg phone. This works fine.
Dec 18, 2008 | LG Vu CU920 Cellular Phone
My daughter just got a lg vu phone for her birthday. She wants a mp3 player for x-mas. Doesn't the phone we bought her have this feature? How do we access it? Are we able to take old music from an ipod and...
well you can accss it by going to your music and if she wants a mp3 than you should get a Micro SD 8 GB so that she can hold music on the phone you insert this card next to the battery first you have to take out the battery though
hope this helps
Dec 11, 2008 | LG Vu CU920 Cellular Phone
Putting music into music folder
All audio shows up under ringtunes, unfortunately. Don't get your hopes up, though; just because it's on the ringtunes list doesn't mean you can use it for one. Ringtunes must be a certain size and filetype for them to work.
It's unusual for music not to show up in the music folder. Make sure you're using the music player in the phone, and not the proprietary network one.
I've never had my music show up in one place and not the other. Usually, it's two.
There's actually a shortcut to getting to the phone's music player. Beside the battery logo, there's a small box with a picture of two windows diagonal to eachother. Touch this. It'll bring up a small list; the first two are internet and Music Player. Hit music player. Done.
Nov 23, 2008 | LG Vu CU920 Cellular Phone
Lg shine - downloading music from my laptop
If you want to put music files from your laptop onto your LG Shine, you can either use a LG USB cable or a Micro SD Card.The Micro SD card will probably need an additional adapter to have it big enough for your Laptop or PC slot. Once the music files are on the Micro SD card, insert the card into your LG Shine and go to My Stuff". Then, select "Audio and ringtones" and select the file on your memory card. Press the "Options" button and select the copy function and paste it into your phone.
Jul 28, 2008 | LG Shine KE970 Cellular Phone
LG Vu CU920 Cellular Phone Logo
3,221 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
