Question about Emerson EWF2004 20" TV
TV stuck on input # 2
Model # cr202em9.... Serial # t14816442, the tv will show a picture from camera on input 2, I have two remote controls that can operate all fuctions exept the input for # 3 and the antenna input. TV was made April 2008. Can you tell what component if any that I need to replace?
Try going to menu and channel set and got to add or delete chanels and flip to channel u want the it worked for me try it
Posted on Jan 29, 2009
My remote is thrashed but i want to change the tv to video 1and2 how do i do this without remo
Typical problem for this brand, only a working remote will do what you want.
They do this to sell remotes and a universal likely will not have the functions you want.
You can also google the model number with the word remote after it.
If this information did not help you do not rate this solution.
Aug 04, 2011 | Emerson CR202EM9 TV
Can i plug my ipod into the tv and watch movies
If your iPod plays video, you can use a docking station that has video outputs on it. Connect the yellow/red/white cable to your TV and change to that input. These usually have a remote control. There are some cables that can connect an iPod directly to your TV. Either way just make sure it is compatible with your version of iPod.
Apr 16, 2011 | Emerson CR202EM9 TV
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Feb 18, 2011 | RCA 20F420T 20" TV
I need a remote to my tv because i cant play the xbox
I found it on ebay...
Dec 10, 2010 | Emerson CR202EM9 TV
Cr202em8 universal remote code
If you go to Big Lots and purchase their 4 device RCA Universal Remote, the code 10171 will completely control your Emerson SDTV. All functions including Inputs will work with that particular remote. The beauty is it's only 8 bucks.
Sep 19, 2010 | Emerson CR202EM9 TV
I purchased a used Emerson TV Model 3 CR202EM8 and dont have manual or do I reset password to access screen to enable me to change to video mode
go here if you cannot access the site: here are the instructions:
Your password will be erased and return to the default
(0000) when a power failure occurs. If you forget the
password, unplug the power cord for 10 seconds to restore
the password to 0000.
Sep 07, 2010 | Emerson CR202EM9 TV
I can not get the emmerson tv i have to go into video mode. I do not have the origional remote that came with the tv or the manual. The remote i have is programed with direc tv. how do i get the tv into...
In the upper left hand corner of the DirecTv remote there is a button labeled "TV INPUT" just push that button. Each time you push it it will change the inputs for the TV. If that is not the problem, the remote needs to be programmed with a code for your TV. If that is the case push the MENU button under the circle in the middle of the remote. Scroll down to PARENTAL, FAV'S, & SETUP, push the yellow SELECT button in the middle of the circle, scroll down to SYSTEM SETUP, then scroll down to REMOTE and push the yellow SELECT button again. From there you should be right as rain. On my TV and setup, I have a device hooked up through DVI, but the TV won't recognize it unless it is powered on. In otherwords when pressing the TV input on my DirecTv remote it doesn't show the DVI device (PS3) unless it is powered on. I hope this helps and good luck. Please vote and leave a message.
Oct 30, 2009 | Emerson CR202EM9 TV
What channel do I set my TV to in order to play a DVDdisc?
Assuming your DVD player is properly connected to the video and audio inputs of the TV, you should be able to press the "input select" button on the remote and toggle between TV and DVD. A copy of your manual is here:
Oct 14, 2009 | Emerson CR202EM9 TV
Cant change channels or input using front panel/no remote
Buy a new remote,tries this website for an exact remote or very closse to the original.1-800-Factory Original.
Sep 30, 2009 | Emerson CR202EM9 TV
Emerson EWF2004 20" TV Logo
158 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
