Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Wd 640 f05 showing on display
  • 1 more comment
  • Bernice Robinson Taylor
    i am disabled and rely on my washer dryer so any help would be helpful thanks
    thanks very much very helpful
    thanks very much tried your solution and it worked very greatful
  • Hotpoint Master
  • 3,463 Answers
Error code F05 indicates that the water level switch is stuck in the closed position, this is probablly due to a blocked filter or pump.
To gain access to the pump and filter, remove the lower rear panel of washer, locate and remove large black hose fastened to the bottom of tub.
Remove filter inside hose and clean, check inside pump for any blockage or restriction, and make sure the plastic chamber is clean where the small plastic hose is fastened to, as this goes up to the water level switch, and can sometimes get blocked.
Refit filter and hose, making sure it is securely on and fastened, and test, if fault still persists, then you will probably neeed to fit a new water level switch, or preesure switch as it is usually called.
Please rate my solution to your problem.
Posted on Jan 28, 2009
Washing machine keeps stopping and showing F05 on display. Washing is now still in machine with water!!
I would say that the pump has storred working. Either it is jammed, (sock/nanky) or the motor has possibly failed.
Jan 04, 2011 | Microwave Ovens
HP 640 fax only displays bars nothing else will work
while the printer is powered on.....unplug the power module and then press and hold the # 3 button at the same time......while holding the two buttons reconnect the power module......will fix the problem.
Jun 01, 2010 | HP 640 Inkjet Fax Machine
F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Feb 03, 2010 | Indesit W 123 Front Load Washer
Aquarius WD 640 showing F- 12 what does this mean
F12 means a communication error between boards.
Check all connections to and from boards.
Hope this helps.
Jan 14, 2010 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aquarius washing machine wd 640 is showing the fault h2o
The code h20 indicates means (not filling)
check the tap/s, hoses, and water inlet valve/s.
Please leave feedback.
Nov 12, 2009 | Hotpoint Aquarius WD640 Front Load...
F05 on screen
Hi. This is a water temperature sensor issue.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F05" error code will be displayed.
Possible Causes / Procedure
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace any parts that is malfunctioning or defective.
Oct 04, 2009 | Washing Machines
f05 means a blockage usually. check the drain hose is clear and there may be something in your filter or pump.
Jan 27, 2009 | Hotpoint Aquarius WD640 Front Load...
Click on the following link for diagnoses and troubleshooting tips for the "F05" Error code.
If you have questions and/or require further assistance, please post back and let me know. I hope this helps you.
Jun 12, 2008 | Washing Machines
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
353 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
