Question about Hotpoint BWM12 Front Load Washer
My bwm129 hotpoint washing machine wont stop washing
vest6
  • 196 Answers
SOURCE: hotpoint bwm129 lights flashing
What mode are you starting this machine in ? I know this may sound silly and I'm trying to determe if this is a machine fault code or something else.
Posted on Jan 02, 2008
ginko
  • 19396 Answers
SOURCE: I have the hotpoint BWM129 super silent 1200 spin,
The flashing lights means that an error had been detected.
The machine must be unplugged from main to check the drain hose and the drain pump.
The most common is that the drain pump is clogged with debris and must be unlocked.
Posted on Feb 18, 2009
barkencoa
  • 3463 Answers
SOURCE: f-01 error hotpoint WMD960P
Error code F01 is indicating ashort circuit motor triac.
Check connections on motor the motor plug and then control module.
Please rate my solution.
Thanks.
Posted on Nov 18, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Posted on Jan 10, 2010
beltronic205
  • 1460 Answers
SOURCE: hotpoint aquarius wf101 washing machine wont start
fit new door interlock switch not too expesive parts about £15
Posted on Apr 07, 2010
I have a Hotpoint BWM129 washing machine and the Delay start and Superwash lights are flashing. Can anyone explain what fault code this is? The door locked light is also on.
Manual says to unplug maching from wall for at least 40 seconds to a minute. This will reset the unit. If that does not work you will need to call a service tech.
Jan 30, 2015 | Hotpoint Bwd12, Bwd129, Bwm129 Washing...
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Bwd129 not draining
if your dishwasher is stopping on the drain cycle and not draining it could be a problem with the timer not kicking in to drain mode. or if it completes the entire cycle and not draining it is your pump thats bad. hope this helps.
Feb 22, 2013 | Hotpoint Bwd12, Bwd129, Bwm129 Washing...
THE FABRIC CONDITIONER COMPARTMENT ON MY BWM129 WASHING MACHINE IS ALWAYS FULL OF WATER CAN YOU TELL ME WHATS WRONG
Hotpoint BWM129 This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 01, 2010 | Hotpoint Washing Machines
Hotpoint bwm129 wont finish a cycle. super wash and rinse hold lights are flashing.have checked pump for obstructions and waste pipe. any suggestions?
Have you checked the filter? even if the pump is o/k, if the filter is blocked, it will not empty..
If filter clear, then you have a more serious problem.
Hope this helps.
Dec 02, 2009 | Hotpoint BWM12 Front Load Washer
Hi my washing machine model bwm129 bearing has
Hi, most engineers would charge £90 just for the bearings. It's quite a big job.
Hope this gives ou some idea.
Sep 28, 2009 | Washing Machines
I have a Hotpoint BWM129 - it has stopped spinning - the motor hums and the belt is ok. Can anyone help?
Check the motor if this is still OK. If it is no longer spinning or running, look for the running capacitor.
Note the rating in microfarads or take this off as your
sample when you buy a replacement. Put the replacement in place, and restart. Please let us know
by e-mail and put in your vote for the solution.
Sep 26, 2009 | Hotpoint BWM12 Front Load Washer
Lights flashing & door wont open
Dear RedBikeGirl
I've got a BWM129 which is causing me problems too (the washing is smelly at th eend of the cycle!) - How did you get the filter unit out of its housing, I turns around but doesn't seem to want to come out!
Any help gratefully received
Jun 01, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint bwm129 making huming noise
Sounds like the rinse water can't come. Maybe the solenoid for cold water got stuck or a water filter needs cleaning? If the humming is louder, perhaps the drum motor (or drum) needs a little care or cleaning.
If all else fails, download the user manual and check the trouble checklist index. (Or; try learning your kenpo succession move sparring against laundry to clean it.)
Apr 14, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint bwm129 lights flashing
Dec 30, 2007 | Hotpoint BWM12 Front Load Washer
Hotpoint BWM12 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
