Question about Health & Beauty
Owners manual mci alien 50 - Health & Beauty
3 Suggested Answers
Adrian762
  • 425 Answers
SOURCE: i have an mci alien 50cc scooter the oil light
Three things will cause this:
1: The sensor is cactus
2: The sensor is blocked (with gunk) and can not function.
3: There is no oil pressure to make it function.
2 is easy, you just take it out and clean it, if the problem is rectified then all is well. If not, you replace it, if the problem is rectified then all is well. If not you take it to a reputable bike mechanic, or get a manual and get it fixed. But I did not think that small bikes used oil pumps, I was of the opinion they used the oil spash technique. Could be wrong??????
Posted on Feb 06, 2010
SOURCE: oil light
the oil sender [switch] is plugged into the oil tank check the wires are still plugged into wireing lume if so the switch will more than likely to be at fualt
Posted on Feb 16, 2010
How much coolant goes into a 95 Plymouth voyager mini van
If you look in your owners manual it should have a section title "Fluid Capacities". If you can't find your owners manual you may be able to look for your manual online. Just search for something like "95 Plymouth Voyager owners manual" and you should get a hit. But typically it's not much more than 2 gallons if it's REALLY empty.
Don't forget that you should mix anti-Freeze 50/50 with distilled water!!!
You can buy anti-freeze that is already mixed 50/50 so you don't have to mix it with distilled water.
Dec 03, 2015 | Plymouth Cars & Trucks
Code 2103
Developer motor MCY error
After developer motor MCY is
driven, the ready signal does
not turn to L within 5 s.
stabilized, the ready signal is
at the H level for 5 s continuously
Aug 08, 2014 | Kyocera Office Equipment & Supplies
What is error code c/6 400 on koycera km2020
Developer unit
MCY
1. Check that the developer waste lock has
been released and, if not, release the
lock (see page 1-2-15).
2. Check that the gears and spiral screw of
the developer unit are not damaged.
3. Confirm that the developer roller can
rotate.
4. If it won't rotate, replace the developer
unit (see page 1-5-57).
Developer motor
MCY
1. To check the motor operation, execute
DLP(MCY) by U030 (see page 1-3-34).
2. Check the drive gear can rotate or they
are not unusually loaded and, if
necessary, replace.
3. Confirm that the wiring connector is
firmly connected and, if necessary,
connect the connector all the way in.
Developer motor MCY and Motor
control PWB (YC7)
Motor control PWB (YC3) and Engine
PWB (YC9)
4. If the wiring is disconnected, shorted or
grounded, replace the wiring.
5. Replace the Developer motor MCY.
Motor control PWB Replace the Motor control PWB
Engine PWB. 1. Check the engine software and upgrade
to the latest, if necessary.
2. Replace the engine PWB (see page 1-5-
80).
Aug 07, 2014 | Kyocera Office Equipment & Supplies
Runs but not idling
The idle screw is normally found on the carburetor and is a screw with a spring, close to where the throttle cable enters the carb.
Jan 28, 2014 | Quad Cycling
Owners manual for a 50" Hitachi 55vf820
I'm sorry for the difficulties you're experiencing in getting the Manual of the TV. Please click here to download the pdf copy of the Manual.
Please let me know if you require any further assistance.
Oct 19, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a mci alien i bought it new it has full tank of oil but it seems like no oil is pumping into the engine and now it runs for about 2 mins then just completly losses power what is wrong
If your oil tank is full you may have problems with the oil pump or have an obstructed or collapsed oil line. In either case don't use it until you find the reason that you have no oil circulation because it will cause damage to the engine.
Jun 26, 2011 | 2004 Mondial RZ Nuda
I have an mci alien 50cc scooter the oil light remains on even though the oil is full
Feb 05, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Oil light
I have 3 questions i have a 93 intrepid i wanting to get the original keyless entry remote it wass missing when i bought the car and also i need the owners manual and last i need to know what type of...
well first off keyless entry is dealer itam so is owners manual, you can use any antifreeze 50/50 or full strength defrince is 50/50 can not be mixed with water full strenght can only reason is 50/50 is pre diluted full is not
Dec 15, 2008 | 1993 Dodge Intrepid
Health & Beauty Logo
48 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
