Question about As Seen On TV Swivel Sweeper Vacuum
Swivel sweeper brushes slow with full charge even after cleaning brushes
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
When you say you cleaned out brush's are you talking about the build up between the bristles? I've found that I have to take the roller completely off and use fine needle nose tweezers to actually get all the stray hairs and caked on dirt as it hides close to the inside of the brush rollers. It's a bit more work to do this but I think you might benefit from this extra step!
Good Luck!!!
Posted on Jul 09, 2014
2 Suggested Answers
small6363
  • 18402 Answers
SOURCE: swivel sweeper max manual
what is make and model please
Posted on Feb 08, 2013
My swivel sweeper handle snapped right off where it is supposed to lock in place. Do they offer replacement for this?
You would need to check with the company where it was purchased. Some merchants just 'even-exchange' if you bought from a local retailer. Depends also on model/price. If it is lower-end item to begin with, may not be worth your trouble.
Sep 23, 2013 | As Seen On TV Swivel Sweeper Vacuum
What would cause this to shut off after a few minutes of use with full battery charge
1) test the power cord for open, broken, loose or defective with VOM
2) test the outlet wall, for ground improperly, and repair.
3) Most of the time is THERMAL fuse, replace or fix it.
God bless you
Jul 27, 2012 | As Seen On TV Swivel Sweeper Vacuum
My swivel sweeper 2 caught a carpet string and stripped the small plastic gear on the motor. How can I get another gear so I can repair my sweeper? Thanks, Ivol...
We were able to find every part ofr the swival sweeper exact for the gears you are looking for.
You can get a new complete sweeper head for 19.99 at:
http://www.swivelsweepercatalogs.com/
Mar 06, 2011 | As Seen On TV Swivel Sweeper Vacuum
The brush on my bissell prolite multicyclonic vacuum won't turn. It seems like it is jammed, but I checked for anything that might be stuck in it and don't see anything. Is there a reset button?
I had the same problem with my old Bissell sweeper ( I bought a new rotating brush each time this happened then I bought a new sweeper the next time it happened -last Dec. 2009.) Unfortumately I bought a new Bissell and now it is happening again to the new sweeper. I do clean the brush often but what has happened is that the hair somehow gets inside the brush via the end caps???This sweeper does have end caps that can be removed for cleaning --although not that easily when they are locked up. I did this yesterday but before I could remove the end cap I had to use a pin, scissors, etc. anything that I could get into the groove to remove lint, etc. that caused it to lock up. Then when I got the end cap to move a little, I pried it off. I found hair, etc. inside where the metal rod is which I don't think should be happening --I used a seam ripper also to try to get some out. I have owned many different brands of sweepers and have never seen this problem before. Then, I put the end cap back on, however, it was not smooth on the inside--almost like it had melted when it locked up. So, the sweeper brush now moves but it is noisy. I guess I will buy another brush -- but this seems ridiculous for a new sweeper--the customer service rep told me that the brush does wear out.... but not on a sweeper that is less than a year old. There is no wear and tear on the brushes. Oh, and the CSR told me that they haven't had people call about this problem --I am guessing they are just buying new brushes or new sweepers. The sweeper def. has great suction but I think other brands do also..
Nov 11, 2010 | Bissell 17G5 PROlite MultiCyclonic Bagless...
What is causing a slight burning rubber smell when running the vacuum?
If this is a sweeper model with a rotating brush, remove the brush assembly. Clean and oil (3-1oil or similar) the bearings on the ends of the brush. They are usually full of string, hair, and thread which binds the brush. Check the belt for burn spots or other damage. Hope this helps!
Oct 04, 2010 | Vacuums
I bought a new battery charged it, and it starts then slows to a stop?
Possible that the drain of the mottor is exceeding the current requirement of the battery.
So check the battery for voltage and current according to the standard set, then check the vacuum motor to work from another source to determine the currrent factor to confirm if there is a mismatch or poor efficiency.
Sep 16, 2010 | As Seen On TV Swivel Sweeper Vacuum
Brushes don't turn, light works when switched on, battery fully charged
Hello. Generally, when the brushes don't turn you will find that the belt is broken. In some cases, also the brushes will stop if they are clogged up with animal hair, etc. Regards, Joe
Dec 14, 2009 | As Seen On TV Swivel Sweeper Vacuum
Battery or ?
If this model is under 1 year warranty, I would suggest that you take it to a warranty repair shop or that you ask for a replacement. with a Return Material Authorization (RMA) at no further cost to you for shipping.
Jan 10, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Swivel sweeper battery is not charging
The battery is done for sure. take a look here Finally charging for our multi device world and choose the best one for you (by price and seller). cheers
Jan 18, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Vacuums Logo
148 people viewed this question
Top As Seen On TV Vacuums Experts
JoeVacs
Are you an As Seen On TV Vacuum Expert? Answer questions, earn points and help others
