Question about Samsung S23A300B 23in LED 1920x1080 DVI VGA Black 5ms With 1yr Warran
Samsung sa300 vga no display - Samsung S23A300B 23in LED 1920x1080 DVI VGA Black 5ms With 1yr Warran
  • francisgrego
    francisgrego Jan 23, 2013
    hi, im francis electronic technician hir at abv rock compony, hir is someidea to repair your samsung LED, open the panel board and there isa smale parts beetwin the ic magic color, change the in winbond,25X40BVS1G and its mask be 8 pin... and reheat the magic color ic, good luck and be care hull to reheat ok,,,,,
SAMSUNG LED Syncmaster sa300 monitor no response
Oh dear, thats common problem happenned on sa300 series ,
if you luck it can be fixed by update your monitor firmware , other final worst possibility is you must change it bios chip and or eeprom chip.
Aug 16, 2012 | Computers & Internet
I have a samsung syncmaster sa300 that just went blank.
do you mean this monitor have been tried to hooked up with other pc then still no display?. ok if their is a power indicator light at front with no blinking but their is no display ( black screen ) the cause will be either the inverter board has damaged or screen back light is busted .
Jul 25, 2012 | Computers & Internet
VGA CABLES 15PIN
Use a VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
,connect it to the VGA port on the laptop,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
(Color does NOT matter )
A) Laptop OFF, monitor OFF, connect the CRT monitor to the laptop.
B) Turn the CRT monitor on, allow it to warm up.
C) Turn the laptop on. By factory default the display should now show on the external VGA (CRT) monitor.
IF not, there are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor AND external VGA (CRT ) monitor
3) External VGA (CRT) monitor ONLY
Press the Fn key down, and hold it down. At the same time tap once on the Display Toggle-Over key.
IF this is in reference to a Samsung NC10-14ROBL Notebook PC,
the Display Toggle-Over key is the F4 key.
[ http://www.samsung.com/uk/support/model/NP-NC10-KA02UK-downloads?isManualDownload=true ]
For additional questions please post in a Comment.
Regards,
joecoolvette
( Need a VGA connector pinout?
1) http://pinouts.ru/Video/VGA15_pinout.shtml
2) http://images.search.yahoo.com/images/view?back=http%3A%2F%2Fsearch.yahoo.com%2Fsearch%3Fei%3DUTF-8%26p%3DVGA%2Bpinout&w=160&h=160&imgurl=www.bing.com%2Fimages%2Fsearch%3Fq%3DVGA%2Bpinout%23focal%3Dc39c325e6d7bbd7d1b43dbc37441f812%26furl%3Dhttp%253a%252f%252fteletechsvc.net%252fpinouts%252fimg%252fvga_pinout.jpg&size=&name=search&rcurl=http%3A%2F%2Fwww.bing.com%2Fimages%2Fsearch%3Fq%3DVGA%2Bpinout%23focal%3Dc39c325e6d7bbd7d1b43dbc37441f812%26furl%3Dhttp%253a%252f%252fteletechsvc.net%252fpinouts%252fimg%252fvga_pinout.jpg&rurl=http%3A%2F%2Fwww.bing.com%2Fimages%2Fsearch%3Fq%3DVGA%2Bpinout%23focal%3Dc39c325e6d7bbd7d1b43dbc37441f812%26furl%3Dhttp%253a%252f%252fteletechsvc.net%252fpinouts%252fimg%252fvga_pinout.jpg&p=VGA+pinout&type=&no=1&tt=114&oid=http%3A%2F%2Fts1.mm.bing.net%2Fimages%2Fthumbnail.aspx%3Fq%3D4892612529160620%26id%3D948dd2942c3315d2dd2252cd4b849a08&***=vga_pinout&sigr=14ooshh1n&sigi=14huk2q99&sigb=11kfglo0l&fr=moz35
Apr 25, 2012 | Samsung NC10-14ROBL Notebook
No osd menu on samsung sde-4001n dvr
yea no osd menu, it was the same for me, but after a couple test, i found thats because it does not detect de vga cord correctly, duno why only with this model, if you use kvm or a dvi to vga cord, happens , i connected a old vga lcd screen and wala! , maybe after a firmaware update may fix the problem :)
Apr 22, 2012 | Samsung Sde4002 8 Channel Dvr Security...
I have samsung syncmaster sa300 20 led monitor, How to fix Not Optimum Mode Recommended Mode 1600 x 900 60 Hz analog, can not playing games
hi
im from iran
i have a monitor samsung sa300 18.5" that one of ics burn and i cant read his number its 8 pin and is up of the data port input. two crakter that begin by it , is at **22
please help me
Feb 09, 2012 | Computers & Internet
Samsung syncmaster 2033sw monitor, till now i was using a vga cable for the display, but recently i bought a dvi cable and connected it. but its not detecting the display of dvi cable. if i remove the vga...
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Nov 15, 2010 | Samsung Syncmaster 2033SW Monitor
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
Problem with lcd 22'' tv come monitor connection
firstafal youtell that detials you working to onborad vga are addan vga tell ok aftar you insttall that display drivers
Nov 25, 2008 | Samsung Computers & Internet
Samsung S23A300B 23in LED 1920x1080 DVI VGA Black 5ms With 1yr Warran Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
