Question about Dell Inspiron 2600 Notebook
I have a Dell Inspiron 2600 PP04L (at least 10 years old). It will not open flash drives/memory stick, etc. I have been told that it has only 1 TB of storage and that is what is causing the problem wi
I am using this notebook for power point presentations but now that I have my presentations on a flash drive, my old notebook won't open them. I get an error message that the notebook "cannot open high speed devices" or something to that effect. Before I purchase a used replacement, how can I tell if the new device has what I need-- 2 TB of storage? Thanks.
  • 24 Answers
SOURCE: Dell Inspiron 9400 PC Notebook replace hard drive
On the underneath side of the notebook there should be two screws that are usually labeled with a picture of a drum. Remove tham and the drive should slide out. Remove the drive from the tray you slid out and reverse procedure to re-install.
Posted on Jan 31, 2008
  • 39 Answers
SOURCE: Selecting a replacement hard drive for Dell Inspiron 8500
Your new hard drive needs to be an ATA which is the same as IDE. 160gb drives run ~$60 on ebay.
t
The best way to install it is through an internal 2nd drive (fastest) or an external usb drive. I use Casper to do a mirror drive back up from the C drive to the new drive. After that you just need to install the new drive in your drive caddy and you are ready to go, the new drive is an exact copy but bigger. Casper is also an ideal back up utility, if your C drive packs up you always have a bootable spare ready.The first backup can take several hour depending on your second drive connection and following backups need to do only the last changes, usually a few minutes.
Posted on Jan 05, 2009
  • 76 Answers
SOURCE: Dell Inspiron 1545 AC Adapter error message
-check the system battery information and charger information of the computer; restart the computer, while the computer is booting up, press F2 repeatedly; check "battery info"
-if it stated ac adapter = unknown device ; update the BIOS (-visit support.dell.com
NOTE:other computers may have different BIOS, if it is not the same you may have to consult manufacturer
-click on drivers and downloads
-click or choose by service tag
-download the BIOS and install it on the computer)
-check information after updating; if same message AC adapter = unknown device; call manufaturer for a replacement AC adapter, if status has changed it is a battery problem or motherboard, contact manufacturer to test battery
Posted on Oct 04, 2009
  • 3940 Answers
SOURCE: i have a dell studio 1737 laptop i purchased in
0F00:065D is a hard drive read test failure. the hard drive is failing. If purchased in Feb, the system should be under warranty call Dell Tech Support to get a replacement hard drive. (800-624-9896 in USA)
If out of warranty you can get a 2.5 in SATA HDD at Newegg.com for about $60
Posted on Dec 05, 2009
  • 629 Answers
SOURCE: error code 2000-0146 do i
that error actually refers to a hard drive issue/failure. You may attempt a reformat and reinstall, but if it fails, you can proceed to get a new hard disk. You can get in touch with Dell for warranty replacement if applicable, or order a new hard drive. You may then decide either to get the same capacity or upgrade to a higher capacity drive.
Posted on Sep 03, 2010
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
I want to install windos 2003 server on dell poweredge 2600 but the server is very slow i want help
I am not sure what you mean by "slow" so I will anwer in general terms. I would recommend 1st that you make sure the PowerEdge meets the recommended hardware specs for Windows Swerver 2003. (Memory, CPU speed, Hard drive capacity, etc.) 2nd- I would run two Xeon processors instead of one and add as much memory as you can put in your system.
I run MS Server 2003 on one of my servers and here is the configuration that I am using:
2 Xeon 2.8GHz processors
6GB ECC Memory
120GB hard drive for the server operating system (Nothing else is on this drive)
750GB hard drive for all other applications
External NAS storage for files, data, etc. (connected to my netword via Ethernet 5e)
With this setup, my server has been running very well for 6 years now. I do maintanance every week on it to keep it up to par. (Simple dusting, checking cables, etc.)
Good Luck.
C2Solutions
Sep 11, 2011 | Dell PowerEdge 2600 Server
My del inspiron mini has no cd drive so how do i install new programs
Hi! Welcome to www.fixya.com.
You need to put your program on a flash drive or an external HDD and just plug in the to your usb port so you can install the programs yo like.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 19, 2011 | Dell Inspiron Mini 10 Notebook
I cant put inspiron 1525 back together
It could be that you have not insert the memory sticks in correctly this can result in not screen.
1. check to see if you have the memory sticks seated in their slots correctly.
2. remove the hard drive and re - insert it into the hard drive slot.
Jul 31, 2010 | Dell Inspiron 1525 Laptop Flamingo Pink
Dell Inspiron 5100 won't start. Capslock flashes 10 times.
it is because the slot in which your memory is loose.try changing the slot of your ram
if this wont work,then some pin of your ram is loose.go to local computer shop .they will tighten those pins
Jul 25, 2010 | Dell Inspiron 5100 Notebook
Hi im sachin want to purchase 1 tb hard disk of cgate and LCD of ither samsung or sony.... 1. will support an external USB hard drive on this lcd's ? 2.is there any other type of hard disk i need to...
I do not know if the 1 Tb external hard will work on the USB ports on the LCD TVs.
What do you want to store on the 1 Tb USB hard drive and display on the LCD TVs?
Most LCD TVs can access USB memory sticks and display DVI movies (if supported by the TV), photos etc. that are stored on these USB memory sticks.
Try inserting an USB hard drive (borrow one if necessary, can be any capacity) into the USB port to see if it works before you decide to purchase a 1 Tb USB hard drive.
My suggestion would be to purchase a 1 Tb USB memory stick. This would out perform an external USB hard drive.
May 19, 2010 | Dell Dimension 3000 PC Desktop
Dell inspiron 1300 does not switch on
try unseating and reseating the memory one stick at a time in each slot one at a time and try turning on the laptop after each stick reinsertion.
If this doesn't do it then take out the hard drive and dvd drive then turn on ht laptop.
If after all of these steps you still don't get video then the motherboard is bad.
Aug 08, 2009 | Dell Inspiron 1300 Notebook
Slow computer
I'd speak to them again, sounds like you have a faulty stick of RAM, if it freezes then it usually means one of the hex sections of the stick isn't working correctly.
May 25, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell Inspiron 1100 won't read 512 Meg ram.
I had the same problem. I tried several brands of memory unsuccessfully, though they all guaranteed that their products would work with my machine. Finally, my brother (who works in IT) recommended that I go through The Upgrade Place (http://www.theupgradeplace.com/). Great price - less than half of what Dell charges - and the memory worked immediately upon installation.
When I told them that I had a Dell Inspiron 1100 laptop, they said that my PC required proprietary memory (which is true). I paid with a credit card and received the part two days later.
Good luck,
Jay DeKing
Dec 27, 2008 | Dell Inspiron 1100 Notebook
Dell Inspiron 2600 Notebook Logo
18 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
