Question about Plextor PX-740UF DVD RW Dual Layer Burner
Can't load or eject plextor px-740uf via front button
Tray won't open by pushing front panel button, only via paper clip in emergency hole. Also, front panel lamp doesn't light up when powering on. (Don't know if the two are related.)
  • 46 Answers
The burner may be defective. That's all that I can think of. Sorry
Posted on Jan 27, 2009
Disk will not eject
In some cases the disk tray will stick in the closed position. Keep trying to get it open with the actuator (open button) but if it fails, look for a small hole on the front panel and insert a small paper clip end into the hole, push, and the tray will open. By hand, sip the tray in and out several times to help free up the tray and remove dust or debris that collected over time.
Jan 05, 2015 | Westinghouse Televison & Video
Manual eject button
Use a small paper clip. Insert paper clip in the faceplate's small hole and push it; the DVD tray will be opened. Actually, there is an emergency button in the hole.
Feb 20, 2014 | ASUS Computers & Internet
My acer x1700 cd drive wont open.. i can hear it attempt to open. i do not have an emergency bottom or push out hole. please help many thanks
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you continue having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Oct 23, 2012 | Acer Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Dvd door won't open for Sanyo DVW 6000
If you are trying to eject a disc, look closely at the front bezel of the drive, there is a small hole near the eject button, push a paper clip into the hole (straightened paperclip) and the tray will be ejected.
If the DVD door is stuck and will not open through ejecting via the icon in My computer, or the eject button on the bezel will not work, you likely have a faulty drive that will need to be replaced
Jul 22, 2011 | Computers & Internet
My disc won't eject and there's no hole for paperclip.
If your DVD Drive came with the computer originally your DVD Drive should have an emergency eject hole.
Kindly check the emergency eject hole just on top of the eject button you will see there a hole where you can poke using a paper clip.
May 29, 2011 | Dell Vostro 220 Desktop Computer
How can I manually open the DVD drive on SONY Vaio PCV 7762 desktop? The drive does not open. There is no DVD in the drive & to my knowledge it was not attempted to be open while in sleep mode, nor...
You can manually open the DVD drive by inserting a strsighten paper clip into a tiny hole just beleow the drive tray. Push the paper clip into this hole gently and the tray will pop out slightly, then grab the tray and pull it out until the tray is in the fully opened position.
Jul 30, 2010 | Sony VAIO Digital Studio PCV-RX860...
DVD will not eject via front button. Is there
Hi mplyler
If you look at the front of the drive, near the open button, you should spot a hole about the size of pin. This is a manual release button. Now you need either a pin a paper clip to firmly push in to this hole and hopefully release the CD tray.
Hope this helps and good luck!
Scott
Feb 02, 2010 | Fantom Drives DVD±RW Dual Layer...
Will not eject DVD is working is stuck I think I might need to open laptop
Power down the laptop and restart it. As soon as it restarts press the open button on the dvd drive and it will open. You may have to try a few times but it will work.
Sep 29, 2009 | Dell Studio 1737 Laptop
Plextor PX-740UF DVD RW Dual Layer Burner Logo
457 people viewed this question
Top Plextor Computers & Internet Experts
Ben Armstrong
xkikbxr
Are you a Plextor Computer and Internet Expert? Answer questions, earn points and help others
