Question about GE Dryers
Drum is making noise like it dragging - GE Dryers
  • ed58315 Jan 28, 2009
    GE dryer model DWXR473ET3WW
    Problem Solver:
  • 5 Answers
Washer or dryer?
What make?
Posted on Jan 27, 2009
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Aug 04, 2013 | GE Dryers
Drum makes noise when turning
You have 2 wheels the drum turns on replace these they look like small roller blade wheels they are located in behind the front door at the near bottom and it requires 2 of these rollers one on the left one on the right. Thanks they may cost 20 30 bucks for both. Remember to rate my solution and give testimonial this is how i earn my achievements here on FixYa Thanks in advance
Apr 26, 2012 | LG DLG5932W Gas Dryer
Replaced the rear brake pads and 1 side is dragging. i adjusted them and cannot adjust any more and still drags and makes noise?
Pull the drum off and check that side again. Maybe a shoe is slightly off track (not positioned properly, or a spring in the wrong hole, something like that). Compare both sides to see that all is correct. Check your emergency brake for proper positioning, too.
Self-adjusting? You did reverse, brake, reverse, brake to set the self-adjusters, right?
Good luck.
Nov 27, 2011 | 1997 Geo Prizm
My car makes a drumming sound at the rear end of the, do I replace the struts or shocks on it?
Struts or shocks wouldn't cause a drumming noise. Could be
a bad tire, dragging brake shoe. Is the noise constant or does
it vary with speed? That should give you a hint. Make sure it's
from the rear, location of car noises can be deceptive.
Jan 10, 2011 | 1997 Dodge Neon
Maytag performa electric dyer makes dragging noise drum turns but acts like something catches and makes a dragging or scraping sound
assuming nothing is stuck around drum pull off the front and check the fan. If it is noisy for a few seconds after you stop the dryer then the fan may be stripped on motor shaft. while off you can check the front glides and the rear rollers
Nov 17, 2010 | Maytag Neptune MDE4000 Electric Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Drum is making nosie like it dragging
Your motor that turns the drum could be going bad or the drum might be slowing down due to the axle it turns on might be "locking up". My bet first guess would be the motor.
Jan 27, 2009 | GE Dryers
Dryers Logo
124 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
