Question about Samsung Digimax 530 Digital Camera
Bad Battery My DIgimax 530 has had battery problems for some time now. I know that this problem has not been like this forever. When I put a new battery in, it uses it quite quickly, then says low battery. The only problem is, when I test the batteries with my battery tester, it says that they are partially full (still in the "good" zone). I am just a kid and don't have much money, I use it for the video feature. It's warranty has timed out, Is there a simple solution?
  • 1 more comment
  • fortun81 Feb 17, 2009
    exactly the same problem here and there isnt any support at the SAmsung site. we ought to tell them there is NO support online for there products, why should we buy from them if they cannot offer support. I guess its a throw away society. Shameful that they got so rich and now dont care.
    email them...if it matters we will find out!
  • RV Granny Mar 16, 2009
    I have had problems for a long time with the camera using up batteries extremely fast. I returned the camera when it was still under warranty but nothing was changed when I got it back. I have gotten in the habit of removing the batteries anytime I am not going to be taking additional pictures in a very short period of time. I also found there is no support or even a memory of this camera on Samsung's site. My next camera will be a different brand.
  • lisavox413 Apr 01, 2009
    I have the same problem. My camera worked for just under a year and now when I turn it on I get the "low battery alert" and then it shuts itself off. I've tried all different brands of brand new batteries. I used this product for not even a year and now it's worthless to me. Hmmmmmm, made in China.
This isn't a 100% solution but it did help. I have had this camera for about 5 years now, and about 3 years ago the "low battery" signal kept appearing on my screen, it got to the point where it would just come on then turn off, even with brand new fully functional batteries. I filed it away in my box of useless **** and decided to take it out the other day as I hated relying on my mom's camera. I came to the conclusion that its clearly not a battery issue but the signal telling the camera the battery is low... i noticed the metal tab on the door for the batteries was sitting lower than the plastic guide beside it, i took a pocket knife and bent the tab back out so it was sitting higher than the plastic tab. Turned the camera on and voila! the camera stayed on and was able to take pictures again. I think what happens is after time the metal tab gets bent down to the point the plastic guide makes contact with the battery and the metal tab doesn't. Worked for me I hope it does the trick for others!
Posted on Aug 28, 2009
    Scholar:
  • 66 Answers
I have the same problem, and have found no solution anywhere. The metal tab that was mentioned is not going to do anything except make a good battery connection if was is bad anyway. If one is bad its because the metal plate itself has a coating you cant see and needs cleaned. Best clean the silver metal plate with alcohol (91%) to get rid of any film that might exist. this will allow your camera to now operate again but it does not resolve the low battery issue. I do believe the cameras are flaky. I will open one up and trace the battery connections and see if there is something I can do. If that doesn't work I will experiment with a one more battery added. Look it doesn't work now, and I am not going to pay for repair. You can pick these cameras up for about $10 - $15 or even less. Problem is thats because they have the same problem.
I suspect it's in the voltage regulator circuit. Either the voltage is truly low at the output from the regulator which means the regulator circuit is not working or it is not and the voltage low circuit is messed up and is shutting it down. Possible the reference voltage for the regulator is fried and causing the regulator to output a lower voltage. It might be built in on a single chip where one can't do anything with it. I will get back with my solution or not.
Posted on Feb 25, 2010
  • Ernest Taylor Apr 09, 2010
    I have got my camera working again without it saying low battery.
    I said I would be back and here I am. I will still do more research when I have more time. For now for testing purposes I have a third battery. This gives it 4.5 volts. It turns on and stays on with no ill effects. This camera was one I bought on ebay and repaired, so am not worried about ruining it. The one thing I noticed is that the flash does not go off at the proper time when the camera takes a pic. It will however work with the flash properly in the inside house mode or low light. I am curious if your camera does the same thing,before an extra battery is added. That will give me a clue to see if these two problems are related. The problem of low battery and the flash not working in sync with the picture being taken. What I did was leave the battery door open. Connect the negative of the one battery in the camera to the positive of the extra battery, and the negative of the extra battery to the positive of the other battery that is showing at the battery door. Never close the battery door when doing this experiment. I used tape to hold it in place. No this is not a solution, but i am working on it. At least now I know I can still use my camera. I used alkaline batteries for the test. What would be more closer to the correct voltage would be three nicad batteries. They are 1.2 volts each instead of 1.5 volts for alkaline. That would give you a total voltage of 3.6. Now with that said, My next step will be to use a 3.6 volt lithium Ion battery in one battery slot and use a dummy battery in the other battery slot. The dummy battery is nothing more than hollow plastic tube that has been fitted with the the actual top and bottom of an old battery. Just the metal parts, with a jumper wire to connect top and bottom together. You could use enough aluminum foil to be as hard and as long as a battery and slide it in the battery slot. That way you would a lith battery on one side and foil on the other and you could shut the door.
    Now another way to fix this is to use a lithium ion battery and get a battery holder from Radio Shack to put it in, and then get a power plug to fit the power hole in the camera. You know the one used when you use the AC adapter. It calls for 3.3 volts, but so what! Use a rechargeable 3.6 lithium ion battery or better yet two of them or more in parallel. That way you still have 3.6 volts but will last a long time. get the holders at the Radio Shack store. carry the holder on your person and just plug it in the ac adapter slot. I have not tried it yet, But I am sure it will work. If it doesn't then switch it out with two 1.5 volts in series. I will have an answer and draw out a diagram and take pics of how to make it work with the battery door shut and no cables. That will be next time when I have a bit more time. I will post the how top on my web site. For now you can experiment.
    Clarification: I actually soldered the battery connections and used tape to hold the extra battery in place on my camera
Is there a battery in at&t 530 handset?
The ATT 530 is not a cordless phone, so any suggestions related to base/handset are erroneous.
Dec 09, 2012 | AT&T Lands Phones
Goes through batteries very quickly....often reading "low battery".
run a pencil eraser over the battery contacts on the camera, it works most of the time
Sep 07, 2009 | Samsung Digimax 530 Digital Camera
Garmin Rino 530 battery wont charge
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Nov 15, 2008 | Garmin Rino 530
Beeping camera
Mine did the same thing for forever and was brand spankin new... When the batteries go dead once, I guess it glitches... You can put brand new ones in and it will Still say low battery or act like it anyway. Give it some time. Then try to turn it on again and it will be fine. Also it will say you have a low battery if you are taking too many pics at a time... like snap snap snap and it will shut down... turn it back on in twenty minutes and its fine... full battery. If you can't deal with this... Get a battery charger and rechargable batteries. I am using them now with none of these problems
Jul 07, 2008 | Samsung Digimax S730 Digital Camera
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Samsung Camera mod DIGIMAX S500/Cyber 530
still that happens to me sometimes...this is when you need t o charge your battery over again fully....
Dec 28, 2007 | Samsung Digimax S500 Digital Camera
Battery life
Remove battery for a minute and insert it again.
There is a Battery Type setting in the Menu of your camera.
Do the following:
- Press Menu/ Ok button
- Go to Set Up 2
- Scroll down to Battery Type
Two options under Battery Type:
- Alkaline- if you are using non- rechargeable battery
- NiMH- if you are using rechargeable battery
Oct 28, 2007 | Samsung Digimax S630 Digital Camera
POWER GOES OFF , AFTER PRESSING POWER ON
Make sure the batteries are of good quality and very new. If the probelm persists then it will have to go to the repair shop
Jun 07, 2007 | Samsung Digimax 360 Digital Camera
Samsung Digimax 530 Digital Camera Logo
170 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
