Question about Dell Inspiron 6400 Notebook
Printer won't print
I have a laptop (Windows XP) and a desktop (Windows Vista) running on a wireless network in my home. I can access the internet, email, whatever, from either computer, no problems. But when I attempt to print anything from the laptop to the printer attached to the desktop, I get errors and no printout. I installed a printer driver on the laptop, thinking that might be the problem. Still got errors.
Is my problem correctable with a simple re-definition of the printer or have I screwed something up? Can someone help me fix this problem?
  • r1955l Jan 27, 2009
    Unfortunately, printer sharing was already turned on, so that's not the solution to this one. Thanks for trying.
  • 46 Answers
You have to turn printer sharing on in vista by going to your network map and turn the printer sharing on. This should FixYa! Network Map is located in Network and Sharing Center on the computer with vista.
Posted on Jan 27, 2009
I have HP Officejet 6500 connected via USB to office desktop. I also need print from vista laptops on the same wireless network as the desktop. How do you do it ?
Hi, I just completed this same query this week.
to set up my remote network i followed promts from windows and then had to run my windows xp startup disc on my vista laptop.
After that was complete i had to install the hp printer setup cd onto my vista laptop and connect the hp printer to my router using the ethernet cable. I followed the prompts on the vista as the cd continued to install. then at the end of it all it showed i had correctly installed the printer via wireless and asked me to do a practice print which i did and all seems fine.
I can now print from my vista laptop and my windows xp desktop. I hope this helps
Jun 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
Can't get epson Stylus nx400 to print from wireless laptops. printer connected to desktop with windows xp pro. both laptops use windows vista home premium.
As your printer is not wireless itself you need to shared the printer. To enable this goto Control Panel on your desktop, select printers, right click your printer and there should be an option for sharing. Enable sharing.
Now using your Vista laptops you should connect to your home network (in your case this is probably a wireless router, as long as your desktop is connected to this router too), goto Control Panel, printers, add printer, search for printer not connected to this copmputer (or network printer).
Hopefully the Vista laptops will then pick it up and install it correctly. You may be asked to install the correct driver for the vista machines. Windows should provide you with instructions on how to do this.
Hope this helps, www.PuterCare.com
Feb 20, 2010 | Epson Stylus NX400 InkJet Printer
Vista and xp network
  1. All computers should have installed and enabled file and printer sharing, which you can see and change in the properties of the network connection.
  2. All computers should have enabled file and printer sharing as an exception for the Windows firewall.
  3. Sometimes you need to install the IPX protocol on the network connection.
May 05, 2009 | Computers & Internet
Cannot add printer to PC on network
heres a link for drivers for your machine.....download the proper driver for each individual system and run setup application
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9106&product=EKN033540
Apr 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Setting up printer on home network
Because your printer is not either wireless or network capable, the only way to get the results you need is to purchase a usb print server, hook it to your router, set it up through it's management console, and if your router is wireless, you can hook up to your router and print to your printer with your desktop turned on or off.
Apr 13, 2009 | Computers & Internet
Network Vista Wireless Laptop to XP Desktop & Print Documents
On the desktop machine - go to the printers folder, right click the icon for the Laserjet and choose sharing (enable print sharing). You should be able to name the printer and make it accessible to anyone within the workgroup. If needed you can run the network setup wizard to change the workgroup names on both machines.
On the laptop go to add new printer and choose network printer, you should be able to browse to the desktop machine by name and choose the Laserjet as a printer (whether you want it to be the default is up to you). The laptop will download and install the drivers from the desktop pc to the laptop and set the correct network path automatically.
It goes without saying that the desktop machine must be on in order to print from the laptop in this scenario.
Feb 21, 2009 | Dell Inspiron 1525 Notebook
Networking Problems with Windows Vista
ok..this may be a user access issue on the network..check your admin access settings first
http://tinyurl.com/6qcpgy
Aug 16, 2008 | Samsung ML 2010 Laser Printer
Just purchased laptop with windows vista home premium
If your PC has a wireless card, you can setup an AD-HOC network :
If your PC is XP: http://www.microsoft.com/windowsxp/using/networking/setup/adhoc.mspx
If your PC is Vista: http://windowshelp.microsoft.com/windows/en-us/help/293c504f-b944-4d5d-835c-f080129bd5dc1033.mspx
If your PC only has a wired Ethernet connection, you may still connect the two using a Wireless Access Point/Router.
Once you have the two computers connected, you may do whatever networked operations you would like:
File & Printer Sharing is the most common:
XP: http://www.wellesley.edu/Computing/FileSharing/Windows/win2kxp.html
Vista: http://www.windowsnetworking.com/articles_tutorials/File-Print-Sharing-Windows-Vista.html
Aug 01, 2008 | Apple iPhone 3G
Wireless printer
it sounds as if the printer may not be set as the default printer, so check in the installed printers and check and also check that the printer you are sending the print to is the setup one and not a pdf or microsoft office document printer, this is found on the drop down box when the print option appears. i am also assuming that the printer has worked before from vista to an xp machine as sometimes xp needs a small update to be used with a vista pc on the network
Jun 12, 2007 | Linksys (WKPC54GCU) 802.11g/b Wireless...
Dell Inspiron 6400 Notebook Logo
98 people viewed this question
Alun Cox
