Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Wd640 stuck on test
Hi, i have a wd640 super silent but it al it says is test on display, plz help
Hold both buttons in until dsiplay clears
Posted on Jan 27, 2009
SOURCE:
Aquarius wf620 super silent washer has "test" in
  • to de- activate press and hold the start/cancel button untill all the lights come on.
  • then press and hold the on/off and start/cancel buttons together until d-off appears
that should do it and if not get back to me, there is another way you can do it.
Jul 11, 2011 | Hotpoint Aquarius WF220 Front Load Washer
My HOTPOINT Aquarius + super silent will not tumble dry. it starts off OK but then comes up with Error code F-13 can you tell me what this means
Hello
F 13 is a fault code for water supply,inlet valve or hose connections.
You may try unplugging the machine and plugging back in to reset.
Mar 31, 2011 | Hotpoint Aquarius WD640 Front Load...
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
My hotpoint qasher/dryer aquarinus super silent wd640 1400 spin just says test on displays and does not let me wash :(
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} According to the manual ‘TEST’ should only appear in the display when the hardware key is inserted into the rear socket of the machine ready to commence a test sequence. The only advice I can give is to turn the appliance off and remove the plug from the power socket for at least one minute then plug it back in and try it again. These machines have 3 phase motors and the heat sink on the module retains an electric charge for some time after the appliance has been switched off so be mindful if you decide to venture into the inside of the cabinet.
Jul 06, 2009 | Hotpoint Aquarius WD640 Front Load...
My washer keeps coming up with errors
You have a right mixture of errors,
F11 indicates that the pump is not working.
F05 indicates that the pressure switch is jammed on full.
F04 indicates that the pressure switch is jammed on empty.
I would start by checking the pump is working o/k.
Next locate and clean filter.
This can be found by removing the rear panel of washer.
Locate and remove large black hose onto tub, remove filter and clean, refit same, make sure hose is on properly.
Test for leaks.
If no improvement, then I think your only option is to call an engineer out as it could become quite involved.
Good luck.
Plz rate my solution.
Thanks.
Jan 19, 2009 | Hotpoint Aquarius WD640 Front Load...
Fault code F-07 on the display
Error code F07 indicates the heater relay is stuck, this is not recommended as a D.I.Y repair, my advice would be to call an experienced engineer to look at it, as there may be other probs that have caused this to happen.
Plz rate my soution
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Fault f13
Hi. F13 indicates dryer fan motor or thermistor problem
If you can't hear the fan motor running on the dry cycle then it is probably faulty.
Hope this helps.
Please feedback.
Thanks
Nov 13, 2008 | Hotpoint Aquarius WD640 Front Load...
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
Test display
hi there let your machine do the compleat test cycle again then when it gets to the end press and hold the start/cancel button and the on/off button at the same time for at least ten seconds.
hope this is of some help
Dec 14, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
176 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
