Question about Sharp AR-M237 Copier
How do I reset service error H5-01 on MX3501N?
Sharp MX3501N had paper jam - I cleared all jams - copier has service error H5-01 - how do I reset?
  • 98 Answers
To reset the code, push P * Clear * on the numeric pad
when it says enter simulation number, enter 14 and push the Start button for black and white copies
Posted on Jan 27, 2009
    Brigadier General:
  • 8,619 Answers
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor
  • Rylee Smith
    Rylee Smith Jan 27, 2009
    Also you can Try this...
    This code means you have had to many paper jams in the fuser without removal. Make sure all is clear in the fuser and exit sections.
    Then on the control panel you will press a series of buttonsas follows.
    Press the P, Press interrupt, Press clear, Press interrupt, Enter # 14, Press start, Press execute to reset, Press clear all or cycle on/off.
    Thanks
    Rylee
  • Sharp Master
  • 19,396 Answers
"SHARP AR250 H5-01 Papersensordefective in the fusing unit
Normally you can clean the build up of toner off the sensor, and it'll sort itself out. It also could happen by having 5 paperjams in a row.
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out."
Solution was from boyrevel on error code H5-01 - FixYa
Posted on Jan 28, 2009
  • 11,896 Answers
Unfortunately. you must purchase a Toner Reset Plug
  • Nate Stansfield
    Nate Stansfield Jan 27, 2009
    FIRST TRY THIS
What is mean by call sevices code H5-01 in sharp mx printer
H5-01 means repeated paper jams on the Sharp photocopiers.
Once the paper jam is cleared properly, you need to clear the error condition.
Put it in 'Copy' mode
Press on the keypad:
P * C * 14
Click execute and press 'Yes'
Then press the 'Copy' tab.
This will reset the menu and jam condition.
May 21, 2015 | Sharp Office Equipment & Supplies
How can solve error H5 in sharp 5516s?
P * C * 14
Oct 04, 2014 | Office Equipment & Supplies
ERROR CODE H5-01
Make sure you get all of the paper out of the machine that's jammed in it. Then you have to clear the H5-01 by doing the following at the machine's control panel:
touch P * C *
14 - then the black and white start button
Execute
Yes
the machine will reboot and it should clear the code as long as the jammed paper was removed!
How To Sharp Copier Printer Scanner Instructions Troubleshooting...
Feb 05, 2014 | Sharp Mx-3501n Color Copier Printer...
Error Message - L4-03 What is wrong?
If you had paper jams it will display this error after 3 in a row in the fuser. Double check to make sure all paper is removed from the fuser. To reset, on the keypad press pound star clear star and enter sim 14 and press copy button. reset copier it should turn off and on, test if paper jams there may still be something stuck.
Aug 24, 2010 | Sharp AR-M550U Copier
Sharp MX 3100n showing code H5-01 , what is it,how do I fix
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Feb 19, 2010 | Sharp MX-3501N All-In-One Printer
Sharp 5316 showing paper jam sign at right door but no paper
Shut it off, wait 30 seconds, turn it back on. If the path IS clear, the error will be gone.
Feb 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Jan 24, 2009 | Ricoh Aficio 150 Copier
Help
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
Error code h5-01
Yes H5-01 is when it jams in the fuser 5 times in a row, check the fuser section for a jam, the paper jams up in there and does't trigger any sensors, once you have confirmed that its clear reset with sim code 14
May 31, 2008 | Sharp AR-BC260 Color Copier
WHAT DOES THE CODE BELOW MEAN
H5-01 means the machine has had a jam in the same place 5 times in a row.
Mar 13, 2008 | Sharp AR-M350N Copier
Sharp AR-M237 Copier Logo
1,944 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
