Question about Vivitar ViviCam 4345 Digital Camera
Can't turn on Vivitar 4345 digital camera
I left my camera linked to my computer for a few hours via usb. When i removed the camera from the usb i realised that it wouldn't turn back on. I have tried changing the batteries, this didn't work. Now when i press the button to turn it on, the light on the back of the camera flashes 6 times and the camera doesn't turn on. I have tried connecting it to my computer and turning it on but the same thing happens. I have only had the camera for about a month and something like this hasn't happend before. Please can you help me.
  • harley469 Nov 26, 2007
    usb says power overload when i plug in???? arrrgggggg
    President:
  • 1,114 Answers
Searching google groups shows others with problems after attaching Vivitar cameras to PC's & then not working. The only fix seems to be leaving the battery out until the camera resets itself. If you can get to the setup menu then try the "default" option to reset the camera to factory settings.
Posted on Jul 24, 2007
SOURCE:
Do you sell disc for camera vivitar 4345 to download your pictures on the computer
Having gone over two months without a response to my query, I assume my suggestions solved the problem.
Jun 04, 2011 | Vivitar ViviCam 4345 Digital Camera
Trying to transfer pictures from camera to computor but unsuccessful. windows vista is operating system. please advise
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 15, 2010 | Vivitar ViviCam 4345 Digital Camera
Hi,I went from Windows XP to Vista.Can I still download pics from my Vivitar 4345 Digital to computer? Thank you,Gina
Sure. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. And you won't have to update the card reader when you update your computer or get a new camera.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 07, 2010 | Vivitar ViviCam 4345 Digital Camera
Vivitar 4345 exceeding power limits on usb port
i dont connect my vivicom 4345 with my pc i dispose XP systeme
Apr 01, 2008 | Vivitar ViviCam 4345 Digital Camera
Vivtar 4345 wont turn back on!!!
Are you certain that when you plugged the camera back into the PC you switched the top icon to the wrench symbol? In order for the camera to communicate to the PC it should be on that symbol.
Jan 01, 2008 | Vivitar ViviCam 4345 Digital Camera
Cable for downloading to computer??
Try using a memory card in your camera and using a card reader to upload, its easier than using cables.
Dec 23, 2007 | Vivitar ViviCam 4345 Digital Camera
Software for vivitar 4345
You do not need software really plug the camera in and It should be recognised as a new removable drive and Windows Scanner/Camera Wizard activates.
Aug 18, 2007 | Vivitar ViviCam 4345 Digital Camera
Urgent please
There are 2 probable solutions. 1. The images are "protected" by the camera & will show "locked" when you try to erase them. 2. The SD card in the camera is locked. The solution to 1 is to unlock the images in the playback menu. See page 45 of the manual. Solution 2 is to remove the card from the camera & check the "lock" slider that you can see on the side (although no all cards have this). Set the lock off. You can download the manual from the first link on the following page: http://www.retrevo.com/s/Vivitar-4345-Digital-Cameras-review-manual/id/200bh831/t/1-2/
Aug 07, 2007 | Vivitar ViviCam 4345 Digital Camera
Vivitar Vivicam 4345
Selecting the "format" option in the menu will wipe off your images. basically it reformats the memory card. I would get a card reader, if you havent done so already. I worked with a student today & for some reason we couldn't transfer images from his camera directly to computer via usb + we were getting some error messages when trying to do so. So, I ended up taking his memory card out & used a memory card reader to transfer the images to 'puter and it worked fine.
Apr 28, 2007 | Vivitar ViviCam 4345 Digital Camera
Vivitar 4345
have you tried pressing the left arrow then press the down button when a little menu comes up in the corner?
Sep 23, 2006 | Vivitar ViviCam 4345 Digital Camera
Vivitar ViviCam 4345 Digital Camera Logo
141 people viewed this question
Top Vivitar Cameras Experts
Ekse
Damen Wong
Damen Wong
Jeffrey Groves
Jeffrey Groves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
