Question about HP LaserJet 2430 Printer
How to replace fuser on hp 1536 - HP LaserJet 2430 Printer
Doc feeder on HP 1536 not working not recognizing paper
The paper sense switch isn't working. It needs to be replaced.
Feb 17, 2016 | HP Office Equipment & Supplies
Hp laserjet 1536 dnf black very low
MY PRINTER HP 1536
PRINT & COPY VERY LIGHT & SCREEN DISPLAY ERROR BLACK VERY LOW HOW TO SOLVE THIS ERROR
Sep 13, 2013 | Office Equipment & Supplies
Paper jammed.sheet stuck approx 9cms out at top.
The problem is the fuser. Lower pressure roller is damaged. Possible wear and fuser fixing film.
can change throughout the whole fuser
RM1-0661-040 ---- HP LJ1010 220V Fuser Assembly
RM1-0660 ---FUSER - 120 Volt Fuser Assembly
or parts of this
http://www.precisionroller.com/search.php?q=hp+1010&x=12&y=5
FUSER - Lower Pressure Roller :  RF0-1002
FUSER - Fixing Film Replacement Sleeve : for hp 1010
good luck
Dec 13, 2009 | HP LaserJet 1010 Printer
I want to fix my Hp laserjet 2840 (Fuser error 50.2)
1. Turn the printer off, wait 10 minutes, and then turn the printer on.
2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Oct 30, 2009 | HP Office Equipment & Supplies
Our HP Color Laser Jet Printer keeps saying 50.2
Hi ellenf971:
Here is your problem.
50.X FUSER ERROR
50.2 error - Fuser Failure (Abnormal Warmup).
Perform the following steps:
1. The connector between the fuser and the
printer is not connected properly. Reseat
the fuser. Check the connector J5013
between the fuser and the printer. Replace
it if damaged.
2. Break in the main thermistor. Turn the
connectors J5013LA-2 (MAINTH) and
J5013LA-1 (GND). If it is not within the rage
of 330k ohms to 50k ohms (at ambient
temperature), replace the fuser.
3. Break in the fuser heater. Measure the
J5013L-2 (FSRH) and J5013L-1 (FSRN)
with the fuser removed. If it is not within the
rage of 12 ohms to 52 ohms (at ambient
temperature), replace the fuser film unit.
4. Faulty DC controller. PCB Replace the
DC controller PCB
you will have to get an HP certified technician to replace the fuser assembly.
Hope this helps
Jul 17, 2009 | HP Office Equipment & Supplies
User error
FUSER ERROR:
. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Mar 27, 2009 | HP Color LaserJet 5550hdn Printer
Printer
You need to replace the fuser, here is an example of replacement part
HP Fuser for LaserJet 5000
These are instructions for replacement:
HP laserjet 5000 fuser instructions
Apr 24, 2008 | HP LaserJet 5000 Printer
HP LaserJet 3030 Fuser Rollers
fuser roller is part of fuser assimble so you need to do is removed first fuser assy set aside and replaced the roller..tnx
Mar 24, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 2430 Printer Logo
160 people viewed this question
Seeker5211
Seeker5211
