Question about Lanier LP126cn Color Laser Printer
Display shows error SC 819 - Lanier LP126cn Color Laser Printer
Service Call SC819
I found that this 'SC 819' occurs if you use the bypass tray for the scanner. I found also that this error can be fixed with an firmware update. See link. http://www.copytechnet.com/forums/showthread.php/32934-Ricoh-Aficio-2035-SC819-Error-Code?p=132762&viewfull=1#post132762
I have no idea how to do that at the moment, and I can't report the success of this way.
Jan 22, 2014 | Ricoh Aficio SP C240SF
Yellow light on front and back panel with no display on monitor
Have you connected to the ALOM to see what is going on during boot? The yellow light is just an indication of a problem, but will not give the much information by itself. This ALOM will provide info before the monitor is initialized. Docs about the ALOM are here: http://docs.oracle.com/cd/E19088-01/v240.srvr/819-4208-10/alom.html
and here:
http://docs.oracle.com/cd/E19102-01/n440.srvr/819-2445-11/intro.html#70482
You will need to connect to the serial port (RJ-45 connector using an crossover cable to the ALOM) from a laptop/PC/terminal and use some type of terminal software to connect over the Serial port of the laptop/system to the ALOM serial port. You may need to try different rates, but settings should be defaulted at 9600 Baud, 8bits, no parity, 1 stop bit.
More info here: http://docs.oracle.com/cd/E19102-01/n440.srvr/819-2445-11/configure.html#17306
A successful connection over this will show readable text a few seconds/minutes after powering up the system.
Sep 06, 2013 | Sun Fire V240 Server
Show my printer on display C8 on Ricoh SP 100Su
Fusing Reload Temperature Error (Fatal Error)
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
Aug 02, 2013 | Ricoh Aficio SP 100SU e Laser...
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Como quitar el error sc 819 de una ricoh 3025
• Software application error
• RAM shortage
• HDD error (hard disk drive )
Apr 06, 2011 | Ricoh Aficio 3025SP Copier
Samsung sc-d353 lcd panel doesnt show any display
check with mains power if that works then battery stuffed
May 15, 2010 | Samsung SC-D353 Mini DV Digital Camcorder
I have a ricoh aficio sp c420dn, when and turn on the screen showing error sc542
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Jan 10, 2010 | Ricoh Office Equipment & Supplies
Panasonic DVD SC-RT70 whilst recording disc stopped and shows error code U61. Recovery process did not work message keeps repeating
I have a SC-RT70 model and there is U61 error code in my dvd player's display. what does this error means?
Jun 16, 2008 | Panasonic Televison & Video
Lanier LP126cn Color Laser Printer Logo
27 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
