Question about Canon PowerShot G7 Digital Camera
Cannot get back to Automatic mode on video
I have somehow changed the settings on my Canon G7 video mode so  it 's in color accent. I don't want it like this. How do I get back to the default setting of Automatic. The booklet says that using Reset All will not work on Color Accent.
  • wlikins Mar 07, 2009
    I have the same problem, but mine is stuck on compact mode and the quality is terrible. Did you ever figure out how to get back to automatic mode?
With camera dial on video, rotate the scroll wheel located around the direction button until Standard is selected. DO NOT push function set first like the manual says.
Posted on Mar 07, 2009
How do I use the "color accent" feature on my SL202?
Advanced: Color Accent To Shoot with Only One Accent Color (the rest in black and white): Turn the mode dial to SCN. Use the arrow directional pad to select Color Accent. User Guide Press SET to edit the accent color. Point the window at the accent color and press the left arrow on the directional pad to set the accent color.
Aug 09, 2013 | Samsung SL202 Digital Camera
Shutter working very slow in AV or P mode, will only work in Auto Was trying out my new lense today when this happened a EOS 75-300 Canon Lense Worked for a short while, when i put my other lens on it...
If the camera works fine in fully automatic mode, but onot in AV or P, it is likely your settings. Trying increasing your ISO (larger number) and increasing your aperture (smaller number). If you don't have sufficient light or a fast enough lens, the shutter be force to operate more slowly. If the camera also has issue in automatic mode, then I would try the following:
Turn off the camera and remove the lens (in a clean, dust-free environment) and lightly clean the contacts on the lens and camera body with isopropyl alcohol. Once your sure the contacts and surrounding surfaces are clean and dry, re-attach the lens. Power on and try...
Aug 04, 2011 | Canon EOS 40D Digital Camera
My canon ixus70 will not take photos,I can view past photos but it will not show image on screen or record digital image ,if I take a shot all I get is a black nothing. Janis jvdzelde@bigpond.com
Issue: How do I reset the camera to its default settings?
Solution: Procedure for resetting the camera to its default settings PowerShot SD750 and SD1000.
Resetting Settings to Their Default Values - PowerShot SD750 and SD1000. 1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sd750resetscreen.gif 3. Using the arrowdownbutton.gifbutton, select [Reset All..] and press funcseticon.gif. sd750resetscreen.gif 4. Select [OK] and press funcseticon.gif.
  • Settings cannot be reset when the camera is connected to a computer or to a printer.
  • The following cannot be reset:
    • Shooting mode
    • The [Date/Time], [Language] and [Video System] options in the setup_icon.gif(Set up) menu
    • White balance data recorded with the custom white balance function
    • Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
    • Newly added My Camera settings
Jul 28, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Reset the date and time to original factory settings
Please follow the steps below to reset the setting to default...
1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sx200resetscreen.jpg 3. Using the arrowdownbutton.gif button, select [Reset All..] and press funcseticon.gif. sx200menudirection.jpg 4. Select [OK] and press funcseticon.gif. sx200resetconfirm.jpg
    • Shooting mode
Feb 19, 2010 | Canon PowerShot SX 200 IS Digital Camera
5ch/7ch stereo in 5 channel mode
Front panel button engaged for 5 or 7 channel operation? Also check front panel rear surround speakers button is engaged. Should get you back to 7.1 unless you have changed the rear surround speaker setup for a 2nd zone, also be sure you have a 7.1 DSP setting enabled.
Feb 22, 2009 | Denon AVR-2105 Receiver
Video shooting went from color to b/white - how do I get it back?
Press the Function button and scroll down to middle (fourth) icon on the left side of the LCD, the My Color mode. Is it set for BW or C? Use the left/right arrow key to select OFF. Press Function again.
Feb 17, 2009 | Canon PowerShot A700 Digital Camera
Canon Ixus 86015
Sounds like you (inadvertently?) had the Color Accent Mode turned on (an icon which shows an eyedropper with an A next to it), which is available on the same menu where you select Manual Mode.
When you press the Func/Set button, with the icon in the top left corner highlighted, along the bottom you will see the options available, including the Color Accent Mode, any of which are selectable by using the left/right arrows and pressing the Func/Set button again.
May 27, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Can't change settings on movie option
To change movie resolution:
1. Set control dial to movie mode
2. Press the Func/Set button
3. Scroll down to the recording pixels icon (probably 320 on yours right now)
4. Use left/right arrow to select 640
5. Press Func/Set button
May 23, 2008 | Canon PowerShot G7 Digital Camera
Can't get normal color in video mode.
We just solved this problem! Rotate the wheel button (above the Display & Menu buttons) to see the various option (Color Accent, Color Swap, Compact, etc.) and stop when you get to Standard.
Sep 12, 2007 | Canon PowerShot A540 Digital Camera
Canon PowerShot G7 Digital Camera Logo
190 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
