In the last month water has started to collect in the lower right crisper drawer and also below the drawer in the bottom of the frig. I don't see a drain hole to clean? I called Samsung and they recommended I blow warm air using a hair dryer into a vent just above the drawer. Did this but the problem returned I also tried lowering the temp setting from 42 to 40 to 38, Still water is collecting? Any suggestions would be greatly appreciated.
SOURCE: Fridge is collecting water under the crisper
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
SOURCE: samsung rf265 series french door
I am having the exact same problem. Please email me if you find the solution. Our water eventually freezed to a sheet of ice. Some water leaks to floor. [email protected]
