Question about Omron Latest Model HEM-780 Automatic Blood Pressure Monitor with ComFit Cuff
How to fix the TruRead mode not working
The TruRead stopped doing its three modes
My watch is 3 hours and 5 minutes off its a shp8948
1. Since all of the settings seem to go through the start/stop button, hold it down for three seconds to put it in "set the watch mode" (when the seconds at the bottom start blinking).
2. Do a quick press of the start/stop button to move from seconds to minutes to hours to years to months to days. The mode button subtracts & the reset button adds.
3. Setting alarms & so on require putting it alarm mode via the mode button. Use the reset button to move to the selected alarm (1-5).
4. Hold the start/stop button for three seconds to "set the alarm mode."
5. Quickly press the start/stop button to between things to set (kind of alarm, hours, minutes).
6. Again, the mode button subtracts & the reset button adds.
7. A three-second press of the start/stop button exits the setup mode.
Feb 27, 2015 | Watches
How to enter maintenance mode KM 3050
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key. 2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion Press the stop key. The screen for selecting a maintenance item No. is displayed.
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
Dec 03, 2013 | Kyocera Mita KM-3035 All-In-One Laser...
How do I put Blue Tube Pro, Bluetooth speaker in pairing mode?
Not sure if this will help but I had the same problem, the speaker would not go into pairing mode and threw away my instruction manual. What I did to fix it is I smacked it against my hand by the three buttons and it went into pairing mode. Do at your own risk but worked for me.
Sep 02, 2012 | Radio Communications
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    May 04, 2012 | 1994 Nissan Maxima
    HOW CAN I GET FIX AND REG OF MY CALULATOR.I AM USING FX 300MS.
    To get out of the fixed decimal mode, press the MODE key until you see the screen giving you the three options "Fix", "Sci", and "Norm". Select Norm 1 or Norm 2. If you select a Sci mode, you'll get "SCI" on the screen in place of the "FIX".
    Press MODE 1 to get out of the regression mode and into the standard calculation mode.
    Jun 23, 2011 | Cameras
    Need remote code for 22lv505 for dish network
    Your code is 750....... Program the remote control in TV mode and then in VCR **repeating the steps** (or AUX - press 1 before entering the DVD code) mode.
    How to program your dish network remote for your tv:
    1. Use the device’s buttons or its remote control to turn on thedevice.
    2. Press and hold the mode button for the device you want the remote to control, for about three seconds. When all the other mode buttons light up, let go of the mode button - that mode button should now be flashing. For example, hold the TV mode button for a TV until all of the other mode buttons light. When you let go, the TV mode light will flash.
    3. Only for the AUX mode, Use a number button to enter 1 for a second VCR or DVD player
    4. Use the number buttons to enter one of the device codes that I have given you.
    5. Only for Limited Mode, Press 1.
    Limited Mode- allow you to only use the remote to Power, Mute, and adjust Volume on your tv.
    You cannot change the tv channel when the remote is in limited mode. You can only power on your
    VCR in limited mode
    ****Note: Skip this step if you do not want to use Limited Mode.****
    ________________________________________________________________
    6. Press the POUND (#) button. If you entered the code correctly, the mode button flashes three times.
    7. Press the blank POWER button to test if the code works for the device. If it does, the device should turn off.
    8. Turn the device back on and try some other buttons to make sure they work. Sometimes, the blank POWER button works when other buttons don’t. If the code works for other buttons
    ** Stop Here**
    Let me know if this helps..
    1388f48.jpg If I have helped you, dont forget to rate!!!
    Jan 03, 2009 | Toshiba 22LV505 22 in. LCD TV
    Need to set the date and can't find manual--
    Try this:
    1. With power off, press the MODE button to select the DATE mode.
    2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
    3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
    4. Use the zoom in (one tree) button to advance the number.
    5. Repeat steps 3. and 4. to set each value.
    6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
    7. Press the MODE button and the power will switch off.
    Dec 22, 2007 | Canon Sure Shot 115u II Date 35mm Film...
    Date and time
    Nov 07, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
    How do you set the time on the Canon sure shot 80u
    Sep 10, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
    RCA Camcorder
    It's been a while since I worked on the RCA full size camcorders as well. It sounds as though the load motor is "jogging" because the mode switch is not in time with the mechanism. I think there are timing marks on all the cams and gears in the unit and an indicator arrow on the mode switch. Set the mechanism to the "stop" mode and align the main cam index mark to the load motor drive cam, be sure the mode switch arrow points to the load motor drive gear "hole", this tells the micro the unit is in "stop" mode. Good Luck Joe Weibel customelectronics.org
    Feb 07, 2007 | RCA CC4252 Camcorder
    Omron Latest Model HEM-780 Automatic Blood Pressure Monitor with ComFit Cuff Logo
    Top Omron Health & Beauty Experts
    Maxumized
    Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
