Question about Samsung Digimax S800 Digital Camera
Three beeps and can't find the reset button
Same problem as a few other posts. The batteries are definetly charged but the camera won't turn on, It just beeps three times, it is less than a year old but have lost the recipt. I can't find a reset button on it anywhere, any other suggestions?
  • 2 more comments
  • Anonymous Nov 18, 2007
    I have the EXACT Same problem, and no reciept.
  • rp1990 Dec 03, 2007
    Three beeps and can't find reset.  Won't close or work
  • lwhitlow1 Dec 17, 2007
    I'm having the same problem, I turn it on, it beeps twice and then shuts off and the batteries are new.
  • RachelMac Dec 26, 2007
    I just came up with the exact same problem. Had the batteries out since yesterday and got the same three beeps. Anyone found a fix yet?
I had the probem, my shuttel was stuck, I open the case and try to open your shuttel with force. That fixed my problem.
Posted on Dec 30, 2007
    President:
  • 1,114 Answers
Try leaving the batteries out for a day or so, the camera should "reset" itself.
Posted on Jul 24, 2007
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
Camera lens is stuck in out position, but screen is not on, beeps three times when i push the on/off button
This may help: connect the camera with the charging cord.
press and hold the ON/OFF button and the PLAY button.
(the one that allows you to see the pictures you just took).
hold them until the light on the charger cord starts flashing and then the screen turns on and the lens retracts.
Mar 16, 2017 | Samsung L100 Digital Camera
Nikon coolpix s8100 will not turn on. i have only used the camera a few times, and it was recently charged. is there a manual reset button? or do i need to send the camera back to nikon?
If it won't turn on, you're not going to be able to reset it.
Other than sending it back, the only suggestion I can make is do you have or can you borrow a spare battery. If so, try that. It could just be a failed battery.
Aug 26, 2011 | Nikon COOLPIX S8000 Digital Camera
S85 camera will not turn on just beeps three times
I figured out the fix:
Take the batteries out, put them back in and close the battery cover. Next, turn on the camera and before it can finish the three beep sequence, open up the battery cover(disconnecting the battery power). Close the battery cover (reconnecting the batteries) and switch on the camera. It may take a couple of tries, but it seems to be a "poor man's reset"
Apr 21, 2008 | Samsung Cameras
Digimax A7: When I turn it on it turns off.
It seems i have the same problem...although my batteries do charge, and i can take pictures. But when I play them back It does this beep beep beep and shuts off and the lens doesnt always close. It's really pissing me off
Dec 20, 2007 | Samsung Digimax A7 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
When I try to turn on, or see pictures stored, it beeps three times and shuts off
called samsung s800 have know power problems return for replacement before warranty expires or they will charge you 58 to fix
Oct 28, 2007 | Samsung Digimax S800 Digital Camera
Camera does not turn on
Hello, reset in this case is not a solution. Maybe your lens is stuck. For further info please contact me at LIVE session. Best regards, Arpi
Jun 21, 2007 | Sony Cyber-Shot DSC-P8 Digital Camera
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
Samsung Digimax S800 Digital Camera Logo
333 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
