Question about Nuwave Twister Blender
Nedd a cup for model no. 22091
Need to order an large cup.
I have a waring pro blender Model WF2111211 It's glass he blade part doesnt come off. motor runs fine but blade really tight won't spin so the motor smells burn out trying to get it to free.
Heat up a cup of water in microwave until boiling in a two cup Pyrex measuring cup. Add one more cup of tap water. Our it in the blender and let it soak. If it doesn't work, repeat but with less tap water.
Sep 15, 2015 | Waring Blenders
In the base, when I put the food in the cup, and the blade cup in doesn't fit the base. it appears the the blade doesn't go down in the base. I need help, I don't know if the base
Lots of questions, not a lot of information. Is the rubber sealing washer in the wrong place. I have no idea what model/brand you have but on most blenders the rubber seal will go between the beaker and blade assembly, not the blade assembly and the collar.
Jun 18, 2015 | Blenders
I need large cups for this.I have not heard from inovations inc.
some wide mouth bottles will fit the blender , does not have to be a cup.
Mar 31, 2015 | Blenders
I need cross blade and flat blade for my Nuwave twister blender model # 22091 is there anywhere I can buy these parts?
I could sell you my pieces for a few dollars plus shipping. It's been a while so not getting hopes up, but if you still have yours, will sell my blades and cups to you. Or if you have a good base I may buy that from you. Mine burned out blending smoothies.
Chasgiltner@Gmail.com
3213457242
Feb 16, 2015 | Nuwave Twister Blender
The cover with large feed tube is stuck. how can i get it of
So frustrating when that happens!
Use some PAM vegetable spray or something similar under the rim. Try to keep it lubricated in between uses (like, spray in with PAM before you store it, or right before you use it again)
Jul 09, 2014 | Cuisinart "DLC-8S 11-Cup Pro Custom 11...
Replacement parts for model 22091
Need plastic bec I broken piece Come off c pictures
Jan 10, 2013 | Nuwave Twister Blender
The power button is flashing red in my ninja nj600
Arrow on lid, Arrow on handle. Line them up. I just did it. I knew it was something simple but I didn't think it would be that simple.
May 29, 2012 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
Need a replacement pitcher for model56200 typeB17
The same thing happened to me. I ordered a new one and they sent it to me in the mail. You can find replacement parts here:
Oct 25, 2010 | Hamilton Beach 56200 Power Work Top...
Oil Leak-Stand mixer
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Jun 18, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Waring blender - new blade
You can call Waring and they can send you a parts breakdown showing the order the parts need to be in. If you still have problems they can go over the assembly with you on the phone or direct you to a service center near you to help.
Feb 21, 2009 | Blenders
Nuwave Twister Blender Logo
35 people viewed this question
Top Nuwave Blenders Experts
eyecam
Are you a Nuwave Blender Expert? Answer questions, earn points and help others
