Question about Craftsman sears 18" Chain Saw Chain ( Model 35084 )
Remington EL 18SB - Craftsman sears 18" Chain Saw Chain ( Model 35084 )
I NEED A REPLACEMENT CHAIN FOR A REMINGTON EL-2 CHAINSAW THANKS FOR ANY HELP.
Take your chainsaw to a saw shop that repairs chainsaws. They should be able to make one for you or look one up and order it for you. I have found shops in the yellow pages looking under saws.
Jul 26, 2012 | Remington Electric Chain Saw
Need replacement chain for remington 14inch, EL-1 and remington LNT Limb N' Trim 8. Could you provide me with current replacement chain information for both?
Hi jvaltha,
Here is a website that carries the chain for your EL-1 saw: http://shoppingcart.msservicecompany.com/default.aspx?ext=true&itemid=091374S&size=small The part number is a replacement for the original chain, which Remington must not offer any more.
That same site also carries a chain for your LNT 8 saw, but there are different subcategores, LNT1, LNT2, and 8A and B. I'll paste the address for the page where you have to choose your option: http://www.desaparts.com/remington-chainsaw.html
FYI, You don't need to buy a remington chain to fit your saws. Just buy a chain that is the right length and matches the rest of the specs on your chain, the pitch etc. .050,.025, and so many teeth per inch and so forth. Then you can buy locally.
Hope this helps. If it does, I'd appreciate a 4 thumbs up...keeps me working. Thanks,
Handie Andie
May 09, 2011 | Remington Electric Chain Saw
No chain tesion adjustmen older (yellow) Remington EL.1 chain saw
just undo the singe nut slightly the pull so chain tightens then re tension the nut....about all you can do on those old models.
Jul 24, 2010 | Remington Garden
I need to know the chain size for my Remington 14" electric chainsaw, Model EL-1
50 drive links; 3/8 pitch; and 0.050 gauge if an original 14" bar your, choose your chain here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Input "Remington; EL-1; 14"; All; All; All"
The one installed is probably green (low chance of kickback), all of them will work provided it is the original bar.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 02, 2010 | Remington Electric Chain Saw
14" Remington chain replacement
I input "Remington; EL-1; 14"; All; All; All" here:
It returned "91VG050G, 91VX050G or 91VXL050G". Please read the triangular warning placards. The original chain is most likely green.
Column 4 says a 14" chain has 50 drive links (the part in the bar groove". Please count them, if you get a different number try a different length bar. The Oregon part number can be ordered on line or if given to a local merchant fabricated in their facility.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 11, 2010 | Remington Electric Chain Saw
Owners Manual for a Remington 2.5 HP 16 '' Chain saw, Model EL-7
Kindly check this link for manual. Please select the correct model:
http://lawnandgarden.owneriq.net/manuals/mfg/remington/remington_chainsaw_product_list.html
Apr 18, 2009 | Remington Garden
Craftsman sears  18" Chain Saw Chain ( Model 35084 ) Logo
51 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
