Question about Hampton Bay 24750 Huntington III Ceiling Fan
Remote control stopped working
The remote control for this fan will not start, stop, change speeds or turn the light on or off. I replaced the battery in the remote, but still no luck. It's the orignal remote and it will turn my TV on and off. I suspect the fan may have seen a transient power surge and zapped something.
  • 5 more comments
  • Donnie5 May 27, 2008
    Neither the remote control and the pull on and off switch works. The night before the fan was working fine. This afternoon the the fan will not come on. Perceived no electric power. Check fuse box all the circuit breakers are on and working ok.
  • Anonymous Jun 02, 2008
    the light and the fan were working fine. then the next morning neither one will turn on. It seems like there is no power, but all the the circuit breakers are ok. help?
  • chique Jun 16, 2008
    H/B 50" (my measure) fan with remote. Came with house. Bought house 4 yrs ago. Remote does change speeds, will not shut off. Lights (4) does nothing. Wife found owners manual. Pinnacle, St Claire. Several models listed, 52". Changed battery. Looked at fan with vegence willing it to stop turning. Fan will not cooperate. Turned off circut breaker in main panel, also it shut off bedroom TV, and fan and lite in the potty room. Wife not happy. CHEERS   VERN
  • ruvane Jun 26, 2008
    My Hampton Bay fan/light model U0707ST fails to respond to the remote except to turn the light on or off. I have not been able to get the fan to work for a long time. What a waste. I think the interface is OK or I wouldn't be able to turn the light on with the remote. Any ideas?
  • cerickson545 Apr 21, 2009
    I have the same problem. My remote will not turn the fan or light on. we also replaced the battery with no luck. Any solutions?
  • Anonymous Apr 23, 2009
    where do i find the receiver for a hampton bay model uc7078t
  • Anonymous Mar 27, 2014
    handset lights up but not performance from fan
  • 51 Answers
Under the dome (where the electrical connections are) is the receiver unit for the fan. It could be that it is no longer working. Also the remote may have dip switches to change the frequency channel (sometimes located behind the batteries) check that these have not been changed or check they correspond to the receiver unit on the fan.
Posted on Jul 25, 2007
I just extended the nipple to 12" long and connected the wires as they where and now the lights work but the fan is running at high speed. the remote turns the lights off and on but I can't control the fan. I have to shut the breaker off to stop ot.
Posted on May 21, 2009
SOURCE:
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
My Hampton Bay ceiling fan runs only on high speed and the remote has stopped working even after changing the batteries. Does Hampton Bay have a life time warranty?
Yes, look up www.hamptonbay.com and get their contact number from them. It sounds like your transmitter (Remote) has failed. If it were the receiver the fan would most likely not work at all.
Jun 09, 2010 | Hampton Bay 52 In. White Redington...
I have 2 fans 1 stopped working 1 remote
Look at the remote code on the remote which is broken, then copy the code on the fixed remote, then you can control anoher fan.
Jul 12, 2009 | Universal Remote Control Hampton Bay...
Need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
May 31, 2009 | Hunter Ceiling Fan Remote Transmitter...
Ceiling fan with light and remote stopped working
It's most likely the receiver for the remote (transmitter) -- it's located under the cover at the top of the fan -- will need replacing.
May 27, 2009 | Hampton Bay 52 In. White Redington...
Lights are on all the time, fan doesnt work, remote does not work
I have changed the remotes on 5 Hunter fans in the last 3 months. They have a problem with how some of them mount, that makes them drop down and vibrate loose. If you do not have a wall switch for it, you may want to go to pull chains, or just replace the remote. It is NOT the controller you hold in your hand, but the part in the fan. (never the easy way right?) The remote is not hard to change, but you DO have to let the fan hang from the holder on the ceiling bracket, It gets too heavy to hold while you change the remote.
All but one of the remotes I have changed, came from a mass market type of builder/handyman store, and they have just replaced the part at no charge.
Dec 21, 2008 | Hunter 52" Ceiling Fan With Light And...
Remote Control
Change the remote control batteries. Because of the motor construction, it needs to turn on in the highest speed setting. This is why it defaults to the high speed mode. Put new batteries in the remote and that ought to fix it.
Mar 04, 2008 | Hampton Bay 48670 Flemish Pewter Finish...
Hampton Bay 24750 Huntington III Ceiling Fan Logo
1,073 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Gene Pitts
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
