Question about Bosch Axxis WFL 2060 Front Load Washer
Need transit bolts
Bosch Axxis Washer
  • 27 Answers
Take the lid off stuff some foam or polystyrene down the back of the drum so long as you dont go off roading with the appliance in the back of the car that should do you
Posted on Mar 09, 2009
Washing down comforter in bosch axxis
Well, it depends, there are a few solutions to this problem, and you can find most of them in the troubleshooter of the manual under this article:
Bosch Axxis Washer Manual
Jan 05, 2014 | Bosch Axxis WFL 2060 Front Load Washer
Need instructions to stack Bosch Axxis washer & dryer - 24"
You can find the manuals at this link
Dec 22, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis Fault code F18
It's a classical error code, you can find all the error codes together with the troubleshooter within the manual under this article:
Oct 02, 2012 | Bosch Axxis WFL 2060 Front Load Washer
I just got a Bosch WAS20160UC AXXIS front load washer with BOSCH WTV76100US AXXIS dryer. the washer and dryer slide across the floor. I then put a rubber mat under it but it did the same thing. What is...
Welcome to FixYa.
i'll start with the most obvious, but still quite common oversight, have you remove the shipping bolts from the rear of the washer ?
The next thing to pay close attention to is detergent usage. Regardless of what one may have been told, "He" detergent has to be used, and even then not too much.
Look for this symbol when buying/using detergents...
These are the most common things that can (and DO ) contribute to the machine acting in the manner you've described.
If neither of these things apply to your situation, please let me know and I'll be glad to assist you further.
Thank you for choosing FixYa and Good luck.
Macmarkus :)
Oct 07, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Walking machine
Check the transport bolts have been removed from the rear, you should see 3 or 4 bolts on the back panel, 13mm heads, going through plastic tubes, remove the bolts and the tubes (if still there) and fit the plastic covers. If the bolts have been removed already, then there could be a problem with the springs or shock absorbers inside the cabinet.
Jul 03, 2009 | Bosch Axxis WFL 2060 Front Load Washer
I am going to relocate a bosch axxis washer and dryer. does the front load washer need special attention when transported?
yes you need to use the two bolts that were given to you when you acquired it to block the drum during transport (otherwise you could damage the axcel)
Jun 26, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis Washer Detergent slot codes; what do they mean?
soap goes in far left
softner middle
liquid all fabric bleach or powder bleach in far right
May 31, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
May 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WFL 2060 Front Load Washer Logo
126 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
